Question about Nokia 3230
Why is my nokia 3230 telling me sim card not valid
5 Related Answers
manujha07
Manu Kumar
  • 56 Answers
SOURCE: puk code
write down the sim no from the sim card
call customer care and ask him to puk code.
they will ask ur sim no
tell him and enter the no in the phone
Posted on Feb 17, 2008
Anonymous
  • 66 Answers
SOURCE: nokia 3230 startup failed
TRY THIS MANUAL FORMAT:
JUST PRESS KEYS *,3 ,call ..While pressing, turn on
the power swicth until formating appears on the screen.
Then just follow for further instructions.. Thank you much!
You can send me email for further results at [email protected]
Kindly rate this soluton!
rg_nardz
Posted on Sep 12, 2008
Anonymous
  • 431 Answers
SOURCE: when i switch on my phone(nokia 3230) my balace deduct 1.50Rs
try formatting *#7370#
Posted on Jan 10, 2009
Anonymous
  • 553 Answers
SOURCE: NOKIA 3230 with RS-MMC card 512 mb.
youe built in memory in the phone or ram is almost full, your memory card is just another storage bank, transfer all your files to memory card from phone memory so that your phone will have sufficient space for booting up your phone, you need to delete some data stored on your phone memory.
you can do this if you want.
remove sim card and memory card make sure that all data have been backup
then type this by opening up your phone without memory card and sim card
type:
*#7780# for normal reset
*#7370# for full reset
Good luck
Posted on Oct 31, 2009
Angelbday27
  • 18 Answers
SOURCE: My nokia 3230 do not detect my sim card & do
If not detect the sim card means it locked to Network,call the service provider and get the code and unlock it....
Posted on Jun 10, 2011
My nokia 3230 do not detect my sim card & do not show network also.Bu it does not show that insert sim..How to repair it??
you can check it with other sim card ,if it remains the same problem ,it may be locked to particular network wont accept any sim card other than the particular network ,you can unlock it and used to other network,try here http://www.onlinegsmunlock.com/nokia-3230/rs7wp9/
Jan 17, 2011 | Nokia 3230
My nokia 3230 desplays the words 'insert simcard'even if simcard is inserted
you can check it with other sim card ,if it remains the same problem ,it may be locked to particular network wont accept any sim card other than the particular network ,you can unlock it and used to other network,try here http://www.prounlocking.com/nokia-3230/rs8wp9/
Jan 10, 2011 | Nokia 3230
I have nokia 3230 i do recieve sms but im unable to send sms
Turn off your phone, remove sim card then turn on without sim card.after a while turn off, then insert sim card again and turn it on.Good luck.
Apr 29, 2010 | Nokia 3230
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} 2630111022 (Unlock code)
Follow this instruction carefully
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} 1 - Switch on your Nokia 3230 without any sim card.
2 - Don't bother as to what is displayed on your Nokia 3230.
3 - Compose #pw+CODE+1#.
4 - The Nokia 3230 would then display the message "SIM Restriction Off" and will be unlocked!
The letter p appears if you press the button star(*) three times quickly
The letter w appears if you press the button star(*) four times quickly
The symbol + appears if you press the button star(*) two times quickly
The CODE (2630111022) you need to enter is the unique unlock code for your Nokia 3230
Nov 08, 2009 | Nokia 3230 Cellular Phone
scan the mmc with the good virus scanner
Oct 31, 2009 | Nokia 3230
Hi i have nokia 1100 the problem is when i put the sim its say sim is not valid
HI,
ERROR:The sim card is not valid.
SOLUTION:
1.Check the sim card with another mobile.
2.Else,the sim card is not registered(which displays the message "sim is not valid") and we have to call customer care and tell them to register your sim card.
May 07, 2009 | Nokia 1100
NOKIA 3230 phone rejects SIM card after it was fallen in water
Take the sim card out and wipe the contacts clean for both the sim card and the phone. You can use a clean business card to clean the phone side.
Jan 24, 2009 | Nokia 3230 Cellular Phone
Puk code
Feb 16, 2008 | Nokia 3230
Nokia 3230 Logo
Top Nokia Computers & Internet Experts
Muntejaya Ginting
Muntejaya Ginting
sandyp4ever
sandyp4ever
Level 1 Expert
Marvin
Marvin
Are you a Nokia Computer and Internet Expert? Answer questions, earn points and help others
