You have this in the wrong product category.
You must select the category, it only suggests you have to decide if the product is in the right category manually. In any event you have a problem wit the charging system on the engine for the battery, you must have either a defective connection in the wiring of the charging system fro the battery or a defective alternator (the part that changes the battery when the engine is running).
SOURCE: do i need to mix the gas in my 1988 ezgo
Most people do not trust the old oil pump used on the 3PG models, me included. Mix 50:1 and you can be sure that the piston and crank will not seize up.
SOURCE: 1999 ezgo golf cart.need to know the whole wireing
When you removed the batteries, a certain procedure MUST be followed. Key switch off, switch to tow position and shift lever in reverse. You must wait until the beeper unit sound dies out then remove the wire from the most NEGATIVE cable. Place in Neutral before installing new batteries. There is a specific sequence to putting the batteries in an EZ-GO cart. Failure to follow this procedure will kill the controller. The Key switch must be off and the maintenance/tow switch MUST be in the tow position when connecting the batteries. Any of the above will cause the controller to fail, due to improper discharge of the PRE-Charge capacitors.
SOURCE: Electric Golf cart only shutters and inches forward
so many possibilities...
does it roll fairly freely? (checking to see if the brakes or rearend seized up)
Are there any "bad" sounds like things grinding? (Connection between Motor and rearend, axle splines...)
If all that is solid, it is likely in the controller.... (it takes a solid charge right... No bad batteries in there or loose connection? might want to check all the battery connections to make sure none are burnt...)
1997.. does it have the electonic speed control by that year? the other possibilty is that the accelerator is not working corectly. they used a resistor system on old ones that has contactors that would get worn out.... Newer ones control a potentiometer(sp) that controlled the speed.
Only a few real components to check, but if you are not mechanically and electically inclined, could be tough to isolate.
peace,
When this started u could charge the battery and it would run for a little time. Now it will not run at all
GAS POWERED GOLF CART. It does nothing
It is the one fixya put it in
