When the cd eject button is pushed the unit hums for a few seconds but the drawer does not open
The loading belt is broken, or the gears are jammed and locked down, either way a major dis-assembly will be required to attempt repair.
I have the same problem on my JVC! Is this a common problem? :s
Very annoying listening to this one disc. It's not locked, there is no hole for a paperclip... So only listening to child songs at the moment...
SOURCE: "Locked" CD does not come out
Turn off the power, and then hold down the "stop" button on the actual system (not the remote). While you're holding down "stop," push the "eject" button on the system and it should say "unlocked." If ever for some crazy reason you might want your tray to lock again, just do the exact same thing until it says "locked."
I have this problem all the time and it's sooooo annoying. It just seems to happen randomly every now and then.
SOURCE: CD PLAYER.SL-PJ26 Drawer does not open
The tray gears are struck or jamed. need to open the unit.
SOURCE: I can't open the cd drawer. Nothing happens when
There is probably a belt that broke or is slipping - need to take it apart.
SOURCE: cd player wont respond
Did you fix it? I have the same problem but can't find any solutions.
SOURCE: JVC /MX-D761T/ compact component system> The
hi,
Is there is power in your system. is there is any power indication.if not then you have to check the Powre transformer, its fuse, and the small standby transformer near the power transformer. If the stanby transformer is faulty then there will no power indication in your system.
If there is power and the cd is not reading then, You have to check the laser pickup unit inside your system. First of all purchase a laser cleaning cd and insert the same in to your system. If will clean the laser pickup unit to some extent. if then also it is not reading any cd then the laser pickup is faulty. As it has a changer mechanisum it will be difficult to you to replace the lase pickup unit.Because you have to remove so many parts from the mechanisum to reach to the laser pickup unit. If so try to consult some one experienced in it.
ok
