What remote control would work with Toshiba 20AF45 ?
Just buy one universal remote control which have set up codes for Toshiba, or an orginal one from the authorised service center for Toshiba.
My husband programed a universal remote that we have for a toshiba 20af45 for the television bur he did not add the dvd player. How do I reprogram the remote so we can play the dvd player as well?
SOURCE: Will the Toshiba 20AF45 TV
Hello
Your Toshiba model is not compactable with digital diretly. You have to buy one converter indeed. OK.
[3] Find the "Recall" or "Setup" button on the Toshiba remote control. After you find it, press and hold down that button until the lights on the remote control turn on and remain lit. [4] Point the Toshiba remote at the device you turned on in Step 2 and press the button on the remote for that device. [5] Begin pressing the "Power" button on the Toshiba remote. Continue doing this until you have turned the device off using the Toshiba remote. Once it shuts off, press "Enter" on the Toshiba remote. The remote will then be programmed. OK.
1. Make sure there are working batteries in the Toshiba remote control.
2. Turn on your television set, DVD player or other device that you want to control with the Toshiba remote.
3. Find the "Recall" or "Setup" button on the Toshiba remote control. After you find it, press and hold down that button until the lights on the remote control turn on and remain lit.
4. Point the Toshiba remote at the device you turned on in Step 2 and press the button on the remote for that device.
5. Begin pressing the "Power" button on the Toshiba remote. Continue doing this until you have turned the device off using the Toshiba remote. Once it shuts off, press "Enter" on the Toshiba remote. The remote will then be programmed
OK.
