Microwave Ovens Logo
Charlie Randall Posted on Mar 27, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My new GE over the range microwave works fine but has a loud buzzing/humming noise when in use
Everything works fine just concerned about the very loud buzzing/humming noise every time I use it and it's only 4 days old
Anonymous
Level 3:
  • GE Master 6,771 Answers
  • Posted on Mar 28, 2012
Anonymous
GE Master
Level 3:
Answers
6771
Questions
0
Helped
1779148
Points
21413
This sound you describe is not normal and should be checked quickly, even if it means returning the item.
5 Related Answers
Anonymous
  • 5911 Answers
  • Posted on Jul 31, 2007
SOURCE: Maytag Rangehood Microwave Loud Humming
Sounds like you just fried your magnetron. Normally when they go bad, they make a very loud noise like what you described. The smell concerns me because you may have ruined the waveguide as well. If the magnetron burns through the protective painted surface of the waveguide, the waveguide is ruined. In most microwave ovens this means replacing the entire unit because the waveguide is not replaceable. Putting a new magnetron in a damaged waveguide will result in the same arcing and eventual failure. In addition to the magnetron, the following components are part of the same high voltage network: HV Transformer HV Diode HV Capacitor Magnetron Thermal Cut-Out Any one of these components could have also been damaged. I DO NOT recommend taking any voltage measurements inside the HV network. Potentials of over 4000 volts can be reached and make it very dangerous for the do-it-yourselfer. Taking resistance readings with the unit unplugged is strongly encouraged. If you decide to pursue a repair, inspect the magnetron tip and inside of the waveguide first. If the magnetron is melted and/or there are burn marks inside the waveguide, a new microwave may be a in order. This actually may be a better option than an expensive repair. I hope you find this advice helpful.
Anonymous
  • 3 Answers
  • Posted on May 15, 2008
SOURCE: G.E. Spacemaker XL1800- Loud constant buzzing noise. Help
My microwave was totally dead. Things I discovered: 1) There is an easily replacable fuse accessed by taking off the top front vent cover (two screws on top, gently massage off) and then the inside plastic grill. UNPLUG before doing this! 2) Pop off two wires on either end of fuse holder for safety. Then pop out fuse and replace. For more extensive help, there is an evelope with a wiring diagram inside the case on the inside wall! Very helpful when diagnosing the surface lamp problem (I forgot to plug the ballast back in when I closed up the bottom).
A
Anonymous
  • Posted on Sep 01, 2008
SOURCE: Ge jvm1650wb005
weve had our fixed before and it's the heating element $75-$100 to fix.
ginko
Ginko
  • 19396 Answers
  • Posted on Apr 27, 2009
SOURCE: GE SPACEMAKER JVM1650
When door open the microwave should not work at all, if the turntable and light come on with the door open , if they do , then this is an additional problem with door switch and must be fixed.
Regarding humming noise and no heath, Test the high voltage capacitor, the rectifier diode.or the magnetron.
If it additionally does not spin and no light, then check also the door switch.
The diode and capacitors can br tested. The capacitor must be allowed discharge before testing, or you risk to get electrocuted, even if power is off. Capacitors can get discharged by shorting their two contacts.
Replace the magnetron if the checks and all of the high voltage component tests are good, but the unit still does not heat.
All locations, and description of this parts can be located using the diagram here: Counter top.
Parts must be tested to find out what is wrong.
Remember that microwaves are potentially dangerous devices if not repaired properly, the job must be done by a competent person.
A microwave energy leakage test must always be performed when the oven is serviced for any reason.
Regarding parts, contact the seller here to purchase parts. (here in UK).
Anonymous
  • Posted on Aug 06, 2009
SOURCE: GE Spacemaker XL1800 hum/buzz noise but heating works
were you able to replace the magnetron? Did it fix your problem? I have the same issue, and so I wanted to find out from someone who possibly tried it firsthand!
When microwave is started, why does it make a loud buzzing sound--like a Skil saw sounds?
Whirlpool Microwave Buzzing Loudly - ApplianceBlog
www.applianceblog.com/.../26531-Whirlpool-Microwave-Buzzing-Loud...
Aug 12, 2011 - 10 posts - ‎2 authors
My Whirlpool MT4155SPS-2 microwave oven has recently started to buzz loudlywhen operated. The sound is getting louder and more frequent ...
Whirlpool making intermittent loud buzzing noise Microwave ...
www.fixya.com > ... > Microwave Ovens
Whirlpool microwave ovens making intermittent loud buzzing noise related questions and answers. Ask your ... ...loud buzzing noise and it doesn't heat. i just tried it again and let it run for 1 minute. ... Question about Accuwave Microwave Oven.
Troubleshooting the Microwave: Potential Problems ...
www.appliancejournal.com/.../troubleshooting-the-microwave-potential-...
If your microwave buzzes loudly and produces no heat you probably have a defective power .... I have a whirlpool oven range and it's less than a year old. .... Humming sound stops when I open door to remove food, but when door is closed, ...
Whirlpool Microwave Ovens - Consumer Affairs
1helpful
GE profile mirowave JVM1350WW002 - won't heat
There three area's of concern, magnetron, "heats food" the high voltage diode, "sometimes crack" the high voltage capacitor, "usually shorts"
2helpful
Microwave buzzes when off
This is the power transformer humming, sometimes when transformers get older you get vibrations in the windings due to magnetic fields generated within the transformer which causes the humming noise, It's more annoying than anything and won't affect the operation of the microwave.
1helpful
GE Spacesaver JVM132K made in November 1993 just died. Made a buzzing sound and went dead. No lights. No camera. No action! Is this fatal?
Buzzing or loud humming is one of the signs the magnetron tube, the microwave source, has gone bad. Since your oven is over 15 years old, this isn't too surprising. It is possible to replace the tube, but it's usually not worth doing. The magnetron is a costly part, and this kind of repair should be left to a professional because of safety concerns. Between part and labor costs, it's often not much more to buy a new oven.
Wont heat. Everything else seems to work. I notice a HUMMING noise while it is opperatiing
A loud humming or buzzing noise would indicate a short on the magnetron circuit, the part that heats the food. These can be expensive to repair since the cost of the magnetron can be as much as a new oven. Get a few estimates before deciding whether to repair or replace.
I press #1 and hit start the blower works and light comes on but no heat
Sounds like the magnetron circuit has failed. It is the part that generates the microwaves that heat the food. It often shorts out, and makes a loud humming or buzzing noise when it fails. It's not usually cost effect to replace since the part alone can cost as much as a new oven.
3helpful
3answers
Ge microwave - making noise
I have a GE counter top microwave oven. When the oven starts cooking (the magnetron turns on) the oven makes a harsh buzzing noise. What is wrong and what should be done?
Loud humming noise when in use
We had this problem with a new GE microwave in our last home. GE service replaced fan assy,.AND added rubber foam around the motor, Loud hum was reduced,but never did completely go away. We learned to live with it/
Top GE Microwave Ovens Experts
vince
NOEL
NOEL
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
