Question about Mitsubishi WT-46807 46" Rear Projection Television
Audio but no picture mitsubishi wt-46807
Couple of weeks ago I noticed that I had a "rainbow effect" or 3D picture when I first turned on my set(new in 2000), after a few minutes or so it went away. Fri the picture went VERY dark and then was almost entirely obscured by several (?) thick, black vertical bars, now virtually no picture. Sound is ok and I could still change channels, no menu screen and I tried the DVD input and nothing either. I could not gett he "error code" to come up. The TV never went off (in 20 min) in order to press the input/menu button. I just want to confirm that is is also the convergence problem I have read so much about - I could give that a try for the $$ involved. I changed out one of the boards a couple of yrs ago for about $100 to fix the picture problem I had then; got lucky, it was the cheaper board. I just want to confirm the extent of the problem so I can estimate the $$
    Top Expert:
  • Mitsubishi Master
  • 14,553 Answers
Did you try the OPTION menu---think I offered that to you a few days ago......
Posted on Mar 28, 2012
6ya staff
SOURCE:
Slinteriors
Sonny Berry
  • 8617 Answers
SOURCE: sound no pic
Convergence ICs are STK392-110 you will need two of them they are available at the link I am posting and they give free instalation instructions with pics and free tech support so you can do the repair yourself.Heres the link.
http://servicemanuals.vstore.ca/
Posted on May 01, 2008
CAYPIANAN
ESTEBAN MERINO
  • 227 Answers
SOURCE: Turns on but no picture, just black, worth repairing? Mitsubishi 46" projection
you have some bad caps, the only problem is that could be a lot of them.
Posted on Oct 01, 2008
MNfisherman
Nate Stansfield
  • 11896 Answers
SOURCE: No picture no sound....Mitsubishi WT-46809
Your Power supply will most likely have to be replaced. Very common, the capacitor's inside these units due tend to get overheated and burn out. You can test power coming from the power supply with a voltmeter
Posted on Sep 30, 2009
dave1645
Dave Naylor
  • 834 Answers
SOURCE: I have a Mitsubishi WT-42311. Last week the
where you saw blue it sounds like your blue crt is shorting out could be just the video amp so
i would suggest you have a tech look at it for and estimate
Posted on Nov 25, 2009
Anonymous
  • 139 Answers
SOURCE: Mitsubishi WT-46807 Bottom of picture cut off
YOU HAVE A VERTICAL DEFLECTION PROBLEM, THE RETURN CAP IS DRYING OUT AND MUST BE REPLACED
Posted on Dec 27, 2009
Tv has audio but no picture. tv was working perfectly fine last night with audio and pic but now no picture
kindly check ur video cable if ur r useing audio/video cables for you tv
if not u need to check for ur tv tube
Jun 04, 2010 | Mitsubishi WT-46807 46" Rear Projection...
My picture is blurry, re-setting the convergance helps
This is a common problem. Its called a convergence failure.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Feb 19, 2010 | Mitsubishi WT-46807 46" Rear Projection...
Dec 27, 2009 | Mitsubishi WT-46807 46" Rear Projection...
Mitsubishi WT-46807 won't stay powered up.
try giving the back cover a thump it may be dry jointed..
Sep 14, 2009 | Mitsubishi WT-46807 46" Rear Projection...
Power light goes on then shuts off after a couple seconds
my friend you have a power supply problem,check the fuses, replace any blown one and if blows the fuse again you need someone with electronics skills to replace one the yokes that is bad,usually is the red.
[email protected]
Jul 27, 2008 | Mitsubishi WT-46807 46" Rear Projection...
Mitsubishi WT-46807 46 in picture bends and the blue red and white all seperates
intermittent convergence fail. suggest re-soldering the 2 convergence output ICs on the middle power board. they are the 2 large devices located on the largest heat-sink on the middle board(looking at from back) once you re-solder them as long as the aren't faulty internally you should be all set.
Mar 28, 2008 | Mitsubishi WT-46807 46" Rear Projection...
WT-46807 HD PRoblems
GO TO INPUTS ON THE MITSUBISHI AND TURN THEM ON, THEY COME IN THE OFF POSITION
Nov 17, 2007 | Mitsubishi WT-46807 46" Rear Projection...
Mitsubishi WT-46807 46" Rear Projection Television Logo
82 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Ekse
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
