I am looking for a manual for an AX-100 electronic typewriter
SOURCE: How to install min L MAR on the Brother Typewriter AX-450
move the printhead to where you want the L MAR set then hit the L MAR button, if you want to move to the left of where the L MAR is set, go to the L MAR by backspacing or the return key, hit the MAR REL button and backspace to where you want the mar set and hit L MAR. the right margin works the same way
SOURCE: AX-90 NAKAJIMA TYPEWRITER USER MANUAL NEEDED
Contact Nikajima @ 1-800-809-7138 they are very helpful.
DickyO
SOURCE: looking for operating istructions for brother ax-26
Here is the link where you can download operation manual for Brother AX-26 for free:
http://www.devicemanuals.com/guide/Typewriter/Brother/Brother-AX-26-Typewriter-Owner%27s-Manual-T0RJNU1qYz.html
SOURCE: i bought a --brother AX-400 electronic typewriter
Move the carrier to the desired position for the new left or right margin using "backspace" or "space"
To move beyond the position of a current margin, first position the carrier on the margin and press "alt +m rel"
When the carrier is on the desired position, press "alt + l mar" (if you are setting the left margin), or "alt + r mar" (if you are setting the right margin.)
The minimim distance between the left and right margins is two inches
SOURCE: I need the owners manual for my Brother Electronic
Hi
On the Brother site, there is one available for the AX-20.
Maybe it is simlar to your machine?
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_AX20_EN_1594.PDF
Hope this helps!
www.manualsdrive is easy !
