Posted on Mar 27, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Connect a denon amplifier pm-510ae to a technics equaliser sh-8058
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Nov 07, 2012
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
165
Points
0
HI all can Someone clue me into bringing out the best sound from my denon amp. Its coming out as "noise" at the moment so I bought a graphic equaliser which is powered but isnt making any difference to the sound and I was wondering if I need to use an adapter?Frustrated techno ******!
Joseph Hoffmann
Level 3:
President:
  • Master 1,756 Answers
  • Posted on Mar 29, 2012
Joseph Hoffmann
Master
Level 3:
President:
Answers
1756
Questions
Helped
409001
Points
4988
Hi Just to let you know what ever you put between the amp and speaker you will degrade the sound quality. Even with the best machines you will muddy the sound. If you read HiFI magizine they will tell you this is true.
But if you don't care about the quality of sound than go ahead hook an equalizer on it. Hope that helps you.
3 Related Answers
Anonymous
  • Posted on Aug 31, 2008
SOURCE: Connection of Amp to Equaliser
Thanks guys, but i solved my problem, i experimented and decided that i would run my DVD player (Aux Out) as a CD player through the Equaliser in [Rec] and from equaliser out [Play] i went into Tape Play on Amp, then i connected my Turntable CD Radio System to the Tape 1 Rec on Equaliser and then from Tape 1 Play on Equaliser went into the Tape 2 on AMP then i could use Aux in on Amp to connect my Laptop via my laptops headphone socket my laptop has an equaliser so i didn't need to connect to pioneer EQ, i also connected a small 5.1 to the DVD's 5.1 and connected 4 *45w Speakers to the AMP. and i can say it was FANTASTIC i couldn't get to 5 on my volume it was un @$#%believable.
My Quote
"Where there's an In, there's an Out".
Anonymous
  • 4234 Answers
  • Posted on Jan 06, 2010
SOURCE: Manuals For Technics
The manuals for these are on paper not electronic files. Is there are particular problem you are trying to solve?
Dan
ortodox1957
  • Posted on Jun 01, 2011
SOURCE: Hi, I have a Marantz PM 57 Amplifier that is not
I have problem with my PM 57.After 5-6 seconds when I turn switch ON,electromagnetic switch inside amplifier cut off power.Please help....
1helpful
Anyone with a manual for technics sh d5000 graphic equaliser spectrum analyzer
Please call or email the manufacturer of your product so that they can send you the manual for your product. This is an efficient way to get that resource. Thank you.
I have a Technics Graphic Equalizer SH-8057. D-13 is completely fried and I can not find any information on it. E.G. parts number, size
These have been around at least since 2011. I can't even find Technics support page. I gather one might dig out the address for support from one of the manuals. But I can't find its manual, either, just one for the SH-8058. You might get some 3rd party support from a n appropriate forum in Tom's Hardware website. I've seen pages advertising this model used for shockingly low price or about $200. And a YouTube that may be in Spanish. So, Ill list some of all that but can only wish you good luck in chasing down a hobbyist site for this vintage setup. https://forums.tomshardware.com/threads/help-with-connecting-80s-technics-audio-components.3579784/
https://www.manualslib.com/manual/1352974/Technics-Sh-8058.html
https://reverb.com/item/41999248-technics-sh-8057-stereo-graphic-eq-programmable-spectrum-readout-14-bands-ex-sound-japan
https://picclick.com/Technics-Stereo-Graphic-Equalizer-Model-SH-8057-fully-194206894007.html
https://www.ebay.com/b/technics-sh/bn_7024744741
https://www.fixya.com/support/t11289090-technics_graphic_equalizer_sh_8057
https://www.youtube.com/watch?v=LLr4m7-3EVc
Idealistic graphic equaliser model 31-9081
Connect your Denon outputs to the Realistic main inputs.
Connect your Realistic main out to the Rotel tuner in.
Connect your Technics out puts to the Realistic Tape 1 inputs.
Connect your tape 1 out puts to your Rotel cd inputs.
And you should be good to go.
1helpful
Denon pma-510AE protection triggers
Check the main power output devices for shorts (transistors or IC).
1helpful
Sh-e66 user guide,more information on obtaining a user guide, for stereo graphic equaliser,this was purchased second hand without one.
Go here and register for free to get it...
http://www.hifiengine.com/manuals/technics/sh-e66.shtml
It's one of my favorite sources of free manuals.
Had you web searched "technics Sh-e66 manual" you might have found it on your own.
I have the following system Technics SL-D202,
Since all of your connectors are filled, I suggest you this solution:
Use either of this or this connector (2 connectors, each for every channel) and connect 2 of the input devices (that you don't use at the same time, like cd and tuner) at the same input of the amplifier. Move the line out of the tape deck at the line input that just get free. Don't connect the line in of the tape deck. Use the amplifier connector's for tape to connect the equaliser in - out.
This solution has the disadvantages:
not able to rec to tape (I assume that you don't use this function anymore),
you have to power of one of the devices that are connected together at the same input while the other one is active
And these advantages:
You can use your existing equipment for your proposes without paying more than 0.16$
You can make a quick changeover between equalized and flat audio using the tape monitor switch.
In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer. In case you'd like ask me to create a connection diagram for your case.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Conect eq. with the turntable
hi there, first you have to pit your turntable phono at the pre - amp phono to amplified then after you can put now direct into your equalizer and then to your amplifier
1helpful
3answers
Technics SH -8058
the Technics SH-8058 is a beautiful unit, I got one myself for the past 20 years and never failed y EQuing the sound I want.
I am asuming, you got on your reciever TAPE MONITOR... well, the it is simple,
First, just forget about the TAPE on your Techincs SH 5058
Second, on your Technics LINE OUT, goes on your tape monitor LINE IN
and last; on your LINE IN, goes on your tape monitor REC OUT.
Now, choose you desire componet, and turn on your TAPE MONITOR on your reciever...
enjoy and have fun.
2answers
Technics su-a808 amp & sh-ge70 graphic equaliser.
connect your media source(dvd-cd player)to equalizer in-connect equalizer out to amplifier line in-or aux in-connect amplifier out to your loudspeaker.
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
ZJ Limited
ZJ Limited
Sean Wright
Sean Wright
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
