Question about Rheem Heating & Cooling
Rheem Model No RGDG-10EBRJR - Rheem Heating & Cooling
1 Related Answer
Therinnaiguy
Chandler Ede
  • 1420 Answers
SOURCE: where are the control board
Two possible locations, one would be a small glass fuse or automotive type fuse located on the PC board. The second would be in-line of some of the wiring. The wiring diagram will indicate where it is. Make sure you have the proper wires leading up to the thermostat in order to turn the fan on. You will need a minimum of 3 for heating (R, W and G terminals).
Posted on Mar 12, 2011
What size of ac can i put on rheem furnace model ugph-10ebrjr
i need to know btu rating to give you a answer. more info.
Jul 18, 2015 | Heating & Cooling
How can i tell if my gas valve is bad on my rheum heater md# rgdg 15earjr
1) Copy following link for troubleshoot by type of gas control valve
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
2) Check for crossover that will cause water temps to vary.
http://waterheatertimer.org/Crossover.html
3) Check for tripped TRD.
Pilot flame lights but flutters out when burner turned ON.
http://waterheatertimer.org/How-to-repair-Rheem-TRD.html
4) Symptoms bad gas control valve: If there is no gas for pilot, or TP valve releases large volume of water periodically, or water was suddenly very hot, if water temperature at tank varies widely.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Dec 21, 2012 | Water Heaters
How can i tell if my gas valve is bad on my rheum rgdg 15earjr+
Hello Rardovino
5) Add comment and report what you discover
Condensatrion in the exaust , of rheem rgdg furnace
is this a standard series furnace ( not a high eff. condensing model) ???
Nov 15, 2012 | Heating & Cooling
Where are the control board fuses for a Rheem RGVH-10EBRJR. Fan will not start at thermosat but will start with thermostat red and green wires jumppered.
Mar 12, 2011 | Heating & Cooling
No Heat and I'm Cold
Your preasure switch is closed
Dec 05, 2008 | Heating & Cooling
Heating & Cooling Logo
321 people viewed this question
Top Rheem Heating & Cooling Experts
Lawrence Oravetz
ray gallant
Marat Brikov
Are you a Rheem Heating and Cooling Expert? Answer questions, earn points and help others
