SOURCE: F&P washer lights on and beeps
Clogged pump stopped up drain. If the washer does not think all water was pumped out in 8 minutes then it shuts down. Slow drain is my first inclination.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
We have recently moved house, After installing washing machine in its new position I decided to do a wash. After selecting required wash cycle and pressing the start button the machine filled to the requested level then did nothing, lights were still on ( but no one was at home ) so to speak. After a few truble shooting problems checking level of machine , lose connections etc, I have found machine will go through all cycles if I turn power off at supply ( not machine ) when it stops, leave for about a hour then turn on at power supply again it resumes to the next cycle and again stops until turning off power for about a hour again. It does everything, fills with water, washes, rinses,draines, and spins , but as mentioned you have to power off / on every hour between cycles. AAAAGGHHHH .
