HP Business Inkjet 1200dtn Printer Logo
A
Anonymous Posted on Mar 26, 2012
HP Business Inkjet 1200 will print test page but will not print a document
Black ink light was blinking, replaced with new HP black cartridge, still blinked. Powered off then turned on and light was out. Tried to print a word document the black ink light blinked again. Tried 4 times. Also ran the options for cleaning.
4 Related Answers
Anonymous
  • Posted on Oct 13, 2008
SOURCE: Problem printing with HP Business inkjet 1200 1-800-532-4187 IS SPAM
I have a HP Business Inkjet 1220 Printer, and the block ink cartridge light is flashing. I replaced the cartridge with a brand new one, closed the door, and black ink light is still flashing. I put in another neew black ink cartridge, closed the door, and same issue- black cartidge ink light flashing. I cannot print- what to do?
Anonymous
  • 13 Answers
  • Posted on Sep 02, 2009
SOURCE: Cartridge light blinks
Try cleaning the print head first in the software options on the printer and then lightly with a qtip and alcohol or electronics cleaner. The ink jets sometimes dry up and cause the nozzels to get plugged.
Anonymous
  • 787 Answers
  • Posted on Nov 16, 2009
SOURCE: My HP Business Inkjet 1200 printer always prints
Some of print heads may be failed.First clean very well the contacts on the print heads and printer using piece of cotton and some alcohol.If not help look which color don't print and replace that print head.
Anonymous
  • 241 Answers
  • Posted on May 28, 2010
SOURCE: hp printer power light keeps blinking -- wont print any document
Turn both your printer and computer off then after a few minutes turn back on. This should cancel the print job.
HP ink jet 1200..prints only test page after replacing the yellow cartridge.test page only shows black and blue inks are good.need help.
Important thing: HP inkjet printers having self align technology & its aligns automatically after replacing the ink cartridge/s.In the process of align it will prints align page &it will read it on the model.
Suppose if you replaced yellow cartridge, as usually it will print align page, but if one or more cartridges not printing properly align will not completes. Results every time it will prints the align page when its switching on. Align will completes only when all cartridges/print heads are in healthy condition.. Check the alignpage find out which colors are not printing properly, replace it to over come from this issue. Now you decide what to do?..
1helpful
5helpful
K 7100/7103 cartridge light blinking
Gill:
I have the same problem as Sheillz (Sept.15, 2009)
I have installed a color ink printer and both black and color lights of cartriges are still blinking and I cannot print anything at all. Not even a test page.
Can anybody help me pls?
2helpful
Blinking teardrop light blinking
Blinking drop light on HP6122 signifies an ink cartridge is out of ink. There are two cartridges -- color (larger of two) and black (smaller of two). Blinking drop light only indicates either, but not which. HP6122 service software and print driver are available from HP website http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=83027&lc=en&cc=us&dlc=en&lang=en&cc=us. HP6122 service software has a printer maintenance utility which includes ink cartridge monitor. Use the maitenance service utility to determine which (or both) cartridge is out of ink. With cartridge replacement, printer should automatically print test page, then reset and be ready for printing from your computer. To clear printed documents from print que, open the HP6122 print que via control panel > printers > double-click on HP6122 driver to show que > select document tab > select cancel.
New Cartridge - Black showing no ink
u check ur head is working properly i think this main error of head where u insert balck vartrige if u have same printer then u have check replace the black cartrige find out it work properly then sure ur balck head is damage
4answers
Black is not printing
Try this to unclog printhead.
take out cartridge, locate the hole where ink goes trough, put a can of compressed air and blow it.
put some paper under the printhead to catch ink.
6helpful
4answers
k24674
Grand Canyon Tech
Grand Canyon Tech
