Question about Insignia 42" LCD Flat-Panel HDTV
The ASP Ratio feature on my Insignia ISEDPLTV42 doesn't allow a full screen view - only 2 large black areas on both the right & left sides. I have a Digital Video Recorder (DVR) hooked up to
The ASP Ratio feature on my Insignia ISEDPLTV42 doesn't allow a full screen view - only 2 large black areas on both the right & left sides. I have a Digital Video Recorder (DVR) hooked up to it and it was fine until my kid unplugged his XBOX from the TV. Any solutions?
Posted by Julia Cheng on
SD Tech
    Top Expert:
  • Insignia Master
  • 14,553 Answers
The ratio you speak of is the 4x3 and the set may have locked on it--If you have not tried to: unplug the set from power for a while and plug back in to see if set will reset itself.
I presume you went into customer menu and checked to see if you have the option to change from 4x3 to full or 16x9.
Posted on Mar 27, 2012
5 Related Answers
Anonymous
  • 84 Answers
SOURCE: black square in middle of screen when I use my PVR (like TVO) remote
I would take it back to the store and exchange it for a new one. Any problems with new equipment out of the box like that is a sign of a manufacturers defect.
Posted on Jul 12, 2007
jerryg50
Jerry Greenberg
  • 1691 Answers
SOURCE: Insignia flat panel tv
I don't exactly know your model. I can give you a generic type answer.
I can tell you that when you select to have the full screen, it may not work in the mode for the tuner. The reason is that the programs coming in from your tuner are actualy 4:3. When asking for a full screen you are asking for a 16:9 type format. This would stretch a 4:3 picture.
Have you tried contacting the manufacture, or if you know their local factory support place for your area?
Jerry G.
Posted on May 22, 2008
Anonymous
  • 814 Answers
SOURCE: my insignia 37 inch tv
Press menu and use the up or down arrows to find the audio section adjustments. Press the right arrow and again use the up and down arrows to find tv speakers, Press the right arrow to either turn on tv speaker or turn them off ( This is used only if you are using the output signal from you tv in to you stereo input to have surround sound.) Turn them on to listen to sound from the television speakers only. If this does not solve your problem, Press the mute button on you remote control to release the mute function. If all this does not work the telephone number for Insignia is 1-877-467-4289. Talk to them about you problem and see if your television needs some type of service to restore the sound. Hope This helps you with your problem.
Posted on May 13, 2009
ipodslinger
Steve Brown
  • 688 Answers
SOURCE: cant play my xbox 360 on my 22 inch Insignia tv
Is the TV an High Definition TV?
If it's not an HDMI compatible tv them you will need a regular audio video cable for your XBOX 360
you cn get them all day on ebay or at any store.
Posted on May 25, 2009
panchal643Ja
Jayesh Panchal
  • 279 Answers
SOURCE: Aspect Ratio problems with Insignia 26
Keep your Auto Zoom Off set Full screen than only you will get proper picture
Posted on Jan 21, 2010
No picture on startup , continuous flashing green and orange led
Seems that way. Fact that you saw the logo on screen eliminates the inverter board.
Nov 08, 2015 | Sony XBR-52LX900 BRAVIA LX900 Series 52 3D...
My Insignia TV has a blue screen with parental cotrol the problem is I don't have a Control to pres display how can I unlock it???? HELP:(
Hello
When an Insignia TV is locked, it keeps you from watching all of your channels by only displaying a black screen. Insignia TVs are locked from a single button command on the remote control, so it is easy for you to lock the TV by accident. Since Insignia TVs can be locked so easily, it's important to know how to undo this command and unlock the TV yourself. So, unlock your Insignia TV with the push of a button and once again enjoy watching your favorite programs.
· Find the lock button on the Insignia remote control. The lock button is located on the third column from the left on the second row from the top of the remote.
·Stand within operating range of the Insignia TV, then aim the remote at the TV's receiver and press the "Lock" button on the remote control.
· Aim the remote at the TV and press the channel buttons to make sure the TV is unlocked. When the TV is locked, it shows a black screen and does not allow you to view anything else. If the screen remains black, press the "Lock" button again. If this doesn't work, change the batteries in the remote and start over at step
OK
Sep 17, 2011 | Insignia NS- 27" TV27 TV
How do i get a full picture on my secnium hd tv?
Hello
To get the picture full screen come to screen aspect ratio settings.
The Screen Format feature allows you to change how the image of a 4:3 picture
is displayed on your 16:9 screen. The options are Normal, Zoom or Stretch. If
your TV receives an image with a 4:3 aspect ratio, the image can be displayed in
one of three ways:
Normal The image of a 4:3 video signal is centered with black bars on the
right and left sides of the screen
To get ito this setting mode
Enter the main menu and go to preferences select the screen format; option-2; and change the settings to get a full picture.
OK.
Feb 03, 2011 | RCA Scenium HDLP61W151 61 in. HD-Ready...
Some stations do not come in full screen?
Not all programmes are broadcasted in a full screen format, they may show the programme with black bars on the top & bottom or left & right sides of the screen. If you have the TV in the Auto setting for the Aspect Ratio then the picture will be displayed in that size of format relative to the broadcast. If you want to fill the screen you can try a different Aspect Ratio to one that fills the screen to a wider image if available.
Sep 10, 2009 | Panasonic Viera TC-L37X1 37 in. LCD HDTV
On my Insignia LCDTV26 I have almost 3" of black screen on the right and left side of the picture.
This is normal if you're watching a 4:3 (full screen) broadcast or movie on your widescreen (16:9) TV. You can adjust the screen aspect by going into the Settings Main Menu and selecting System, then Aspect Ratio. I hope this helps!
Jul 22, 2009 | Insignia LCDTV26 26 in. Television
Our TV has only 2/3rds visible. The 1/3rd is black and is not using full screen view. The aspect ratio is set at 16:9. this is also showing up on the DVD mode. No matter what you select for aspect ratio it...
Y Main board has failed.
Y Main controls vertical lines in the picture. Plasma TVs have x2 of these Boards. One for left and one for right. It sound like one of these has failed. Loose connections may also result in the symptom you reported
Jul 20, 2009 | LG 50PG30 Plasma HDTV
Picture is too large. How do you change resolution?
On your television press the menu button to bring up the on screen display. Use the up or down arrows to find the aspect ratio control. Press the right arrow button to change the screen settings. Set the television to the best setting for your viewing pleasure. Hope this helps you with your problem. If you need technical assistance you can call Insignia customer service at this number: 1-877-467-4289. Hope this helps you with your problem.
Mar 29, 2009 | Insignia 37" LCD Flat-Panel HDTV
Jerry G.
May 21, 2008 | Insignia 50 in. Flat-Panel Plasma HDTV
Black and white format on 26" insignia hdtv (720p)
Go to Best Buy and see if they have your same Model on display and change the aspect ratio and see how it is. If it's normal there then to me it sounds like a software up-grade might be in order. It might just have a software glitch.
Mar 17, 2008 | Insignia LCDTV26 26 in. Television
Insignia 42" LCD Flat-Panel HDTV Logo
160 people viewed this question
Top Insignia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
