Takes 24hrs to reload the os, slow realy slow. once os is loaded it runs slow but ok. 2gig ram xp-pro 64 bit can't find anything wrong. switched memory around it is only showing 1.68 gig. after loading os i load all drivers/utys but it allways runs realy slow.reloaded os 3 times same thing each time.formatting takes over 12 hrs. iam running a 80gig hdd need Help....
SOURCE: not seeing other stick of ram
MAYBE YOUR COMPUTER ISNT CAPABLE OF HANDLING MORE THAN 1 GB ram UPGRAPE LOOK AT THE SPECS ON THIS MODEL TO SEE WHAT MAX MEMORY IT WILL SUPPORT.
SOURCE: reloading windows xp
Replacement Drive? If you are talking about a Hard Drive the answer is: You can buy any hard drive as long as it is the same type from any computer store. Take your Hard Drive to the store and tell the sales person that you want another hard drive like that one. You can get another Brand or a bigger size if you want to. Your best bet is to completely reload that hard drive and wipe everything off of it and start all over. You can still buy another Hard Drive (Internal or External) to keep your files backed up. That hard drive could have also went bad.
I am going to give you a lot of things that you can do. Like I said this is a lot of information so you might want to print it out and also copy it to a disk for the future. These things will explain how to check your Hard Drive and also tell you how to keep your system running smooth.
I
can't fix this for you, but if I helped you get it fixed, please rate it as a
fixya not a helpful rating. These ratings let me be allowed to help you
and others in the future.
Turn the system restore off. System restore keeps
everything in restore. Meaning......... If you have spyware or a virus,
it will stay in your system. Run Spybot S&D (This program is free and
is better than using msconfig as long as you go through the settings and
change everything to the highest settings.) Then do the same with Adaware 2008
(sounds stupid to use 2 things for spyware, but one catches what the
other one does not.). I have links on my website
(tandnfamilyelectronics-online.com). These links go directly to the
download so you will not get the run around. You would do good to try a
program called Window Washer (http://www.download.com/Free-Internet-Window-Washer/3000-2144_4-10436825.html?cdlPid=10731707).
This is a great program that completely cleans anything in your computer that
you do not need. It will not clean out anything that you have to
have. I have used this for years to clean out my customers computers and
have cleaned as much as 3 gigs of trash out. If you contact me I will
give you some tools that I have for free that will do a great job on your
computer. I have them ready to download and I will give you the link.
([email protected])
Send me the complete specs of your system and I can help you more. I hope
that this helps you. There is no reason the really buy a program for
spyware when there are free things to use that work great. Free AVG is a
great Antivirus and yes it is also free. It will check your e-mail coming
and going. It will also let your friends now that the E-mail does not
have a virus. It also has a spyware program that is free. This day
and time with all of the spyware out on the net you can never have too many
programs for spyware. I would not run all of them at the same time
though. Make sure that you do not use your computer during any
scan. Defrag is also something to do after you do everything else.
Some people will tell you that should not reload your computer. If
nothing seems to work then sometimes that is the only good way to get it
repaired right. Most of the programs that come pre-installed on a store
bought computer is useless and most are even trail software that causes
problems when they expire. Let me know if this helps at all. Please
rate me if it helps.
HARD DRIVE PROBLEM
This sounds like a
bad hard drive. What make of hard drive is in it?
Figure out what brand hard drive it is first. Then go to the website of the manufacturer.
While you are on the site look for software for hard drive
repair. It could be listed in many
ways. Download the windows version if
you have another computer to test this in.
If you do not have another computer to test this in you will have to use
the Dos version. The instructions will
come with the siftware.
Then you will go through these steps.
Do you have another computer that you can use to
check the hard drive? If you have another computer or access to another
computer you can download a hard drive utility that can diagnose and possible
repair the hard drive. Is it a SATA hard drive? If it is a SATA
hard drive you can plug it directly into another computer that has a SATA cable.
If it is not SATA you will need to buy a converter so that you can hook it up
to the other computer. This will be an
external slim hard drive enclosure. A desktop hard drive can be put in another
desktop and used as a slave drive. Just
make sure that you look at the back of the Hard Drive and make put the jumper
on the slave pins. Then you can run the test through the other computer to
test the Hard Drive. The test will let
you know if the Hard Drive is bad or not.
If you can see your files on the drive you might want to back them up
before you start the test. If it comes
back as good go to the next step.
FIX BOOT
You can boot it up with the recovery CD and run through it
as if you were doing a setup and then when the second repaircomes up..... hit
repair. This should repair any problem with the operating system.
If you want to try the simple way... use the first repair that comes up.
When the screen comes up with a blinking curser hit the number 1 then
Enter........ When it ask you for a password hit enter. There should not
be a password unless someone has put one in it. If there is a password it
should be your master password.
Then type fixmbr and hit enter. This will fix your master boot
record. If that does not work use the second repair. Sounds
complicated but it is not.
CDROM PROBLEMS / Hard Drive Problems
Check your IDE cable inside that plugs into it. This
will be the wide cable. Does it light up? Your power supply could
be going bad. Unplug them one at a time and see if they work. Look
at the jumpers and make sure the last one on the cable is on Master and the
other one is slave. Sounds like a bad cable or connection if you swap the
cable and see if it works.
SOURCE: Computer loading/splash screen pixilated and distorted
if you can, hook the computer up to a different monitor and see if it does the same thing. It sounds like it is an issue with your monitor initalizing but the reboot can complicate things. Also if you have a cd that came with the computer you might want to put it in and see if you can re-install your video drivers. One last thing is to check and see if the reboot might have changed some of the settings on the monitor itself. See if you can reset to factory default or an auto adjust. It depends on the kind of monitor as to wich option you can do
SOURCE: no sound after formatting computer,code 39 error
hi its better to download new driver from here
http://en.kioskea.net/telecharger/telecharger-971-drivers-realtek-ac-97-audio
if still problem remains then
try
(From Toshiba)
http://askiris.toshiba.com/ToshibaSu...0%20 57224959 (driver_audio_realtek_26415A.exe)
http://askiris.toshiba.com/ToshibaSu...0%20 57230084 (ta8audiox.exe)
Note: These are the only Realtek HD sound drivers on the entire Toshiba website (that I could find). HD is the newer audio standard that replaced AC'97
or
dtill prob is here then ask me
