The operating system is stored on the hard drive. If the BIOS can't find the O/S then the hard drive is damaged or the windows installation is corrupted. Boot to the BIOS screen and see if you can see the hardrive listed on the information tab. If you can see the drive, you either have bad sectors on the hard drive or a corrupted boot file. You can insert your windows disc and start the machine. Click install now, choose language and on the next screen click 'repair computer'. Choose 'startup repair' this will rewrite the windows boot files.
SOURCE: operating system
first of all you will have to format your laptop cause when you have vista u cant install xp with it
u will have to install xp first and then install vista
about the driver u will have to do some settings in cmos setup and will have to change hdd type
that will solve your driver problem
so first install xp and then install vista
regarding drivers for xp u will have to visit hp website and chat with a online technical person and ask him to mail you the link for drivers for xp
SOURCE: my hp pavilion xt 565 keeps saying "Operating System Not Found"
A few things can fix this, all depends on what exactly is wrong, it could be the hard drive, you can access the bios and go to diagnostics and run the hard disk scan, if either fail call hp and see if they will replace it, if your out of warranty its failry simple and not to expensive to do yourself. you can also attept a recovery if you have the disks...one of these two will work its a 50/50 hope it helps!
SOURCE: my hp pavilion 4200 i took the hard drive out and
The laptop can't find a hard disk, eirher the hard drive is faulty or not seated properly.
Take out the hard drive and reseat it again then see if the laptop boots up. If it still can't find the hard drive, listen to the hard drive, is it spinning up, is it making clicking noises? This indicates a faulty drive and needs to be replaced.
You can also test the hard drive by removing the hard drive and attaching it to a USB hard drive adapter and then plug it into a working computer's USB port. If the hard drive is OK then the computer will see it as an external drive and you can view and open the files.
SOURCE: I have an hp pavilion dv7. The operating system
Make sure that Wireless switch is turned ON and it's enabled in Windows Mobility Center in the Control panel.
SOURCE: While trying to boot my hp Pavilion dm1 I get
Typically this is caused by a corrupt windows file which can be caused by a bad disk drive or a software error that has screwed up the disk indexes.
Use your Win7 disk and do a system repair (NOT INSTALL). Often this will clear up any problem.
After that it gets complicated and you probably will need the assistance of a local computer store.
