Question about Tag Heuer Aquaracer Watches
Help with synchronizing the digital and analogue settings for Tag CAF1011 Aquaracer watch
Manual or instructions for a CAF1011 Aquaracer, especially the analogue and digital synchronization.
Posted by Joe Colletti Jr on
D. E. Hev
    Genius:
  • 1,187 Answers
Posted on May 17, 2015
5 Related Answers
indays
johnny medrano
  • 111 Answers
SOURCE: Seiko Sportura SNJ007 chrograph watch instructions
good evening ! use the shortes button of your seiko sportura to set the analogue time press it slowly until you search a correct time ! thanks ! good luck !
Posted on Sep 03, 2008
SKW914
SOURCE: how to set up ladies roxy digital watch
I found users instructions on roxy website at:
http://www.roxy.com/search/index.jsp?f=Taxonomy%2FROXY%2F2818169&categoryId=2818071&f=Taxonomy%2FROXY%2F2818071&fbc=1&fbn=Taxonomy|Watches&fbx=0
We were able to program our watch completely!!!
If you look on the back of the watch that you bought on the metal plate, it tells you the style. Ours was the Roxy 70's digital watch, and I found specific instructions at (even if this is not your style, the instructions may work):
http://www.roxy.com/graphics/uc/roxy/manuals/Roxy_manual_watch_70s.pdf
Posted on Dec 23, 2008
ThaMp3Doctor
ThaMp3Doctor
  • 8597 Answers
SOURCE: looking for the user manual for Tag Heuer Aquaracer watch
They were just hiding it:
http://ww2.tagheuer.com/_documents/manuals/EI2252_en.pdf
-Tha Mp3 Doctor
Posted on Dec 31, 2008
David Tolond
  • 2501 Answers
SOURCE: lost instruction to a digital/analogue pod watch
This watch appears to be made by "Suunto" and if you go to their web site, you should be able to find your watch detailed there.
If you then go to "support center", you will see "download center and user guides.
Posted on Jan 05, 2010
David Tolond
  • 2501 Answers
SOURCE: Synchronize analog and digital time on Tissot T33 T-Touch Watch
I could not get any result from entering your model in their web site but the "T Touch online" seems to be a watch that has similar features perhaps.
Their catalogues seem to be generic, so by going to their web site http://support.tissot.ch/?mod_flashPDF/id_138 you may finswhat you need.
Posted on Apr 17, 2010
How do I set the alarm on model wau111a tag watch
  • Pull out the crown to the alarm setting position. The crown is located on the right side of the face of the watch. Pull the crown out until "AL", the alarm indicator, is shown on the watch. Depending upon the model of your Tag Heuer Aquaracer watch, you will either pull the crown out in the first or second position.
  • Select the hours and minuets for the alarm. Once your watch is in the alarm setting position, press the bottom right button on your watch. This will enable you to select the hours and minuets that you want to set the alarm for.
  • Set your alarm. To begin setting your alarm turn the crown clockwise until the desired hour or minutes are displayed on your Tag Heuer Aquaracer watch. If you happen to accidentally pass the alarm time, turn the crown counter-clockwise the get back to the desired alarm time.
  • Save your alarm. When you are ready to save your alarm, simply push in the crown. Once your alarm sounds, to silence it press any button on your Tag Heuer Aquaracer watch.
  • Nov 06, 2014 | Tag Heuer Link Watches
    Tip
    TAG HEUER Aquaracer quartz chronograph manual.
    Follow this link and download original TAG HEUER Aquaracer quartz chronograph manual: http://www.tagheuer.com/the-collection/aquaracer/man/quartz-chronograph/index.lbl?w=CAF1110.BA0804
    on Feb 09, 2010 | Watches
    I need an instruction manual for a Tag Heuer 50 Chronograph Aquaracer mens watch
    Tag Heuer recognizes manuals by watch caliber number, not the watch model. Browse through my Tips and Tricks. There are few Tag Heuer watch manuals. Check out if this can help you.
    Feb 24, 2011 | Watches
    Tag Heuer WK1110A-0. I cannot set the digital time to the same time as the analogue time.
    Page 4 of the Omega manual at this link describes how to synchronise the digital and analogue displays http://www.old-omegas.com/1665en.html - works the same for Tag.
    Dec 03, 2010 | Tag Heuer 2000 Classic Multigraph...
    I have a tag with both chrono and digital readouts. I do not have access to the owners manual and want to sync the chrono and digital time displays. Any suggestions?
    Their web site is not too helpful but if you go to http://www.tagheuer.com/login/?urlBack=/mytagheuer/index.lbl%3Flang%3Den, then you will be able to "become a member" and extract some useful information e.g. local stockists- who should be able to help.
    Sep 21, 2010 | Tag Heuer WAF2110.BA0806 Aquaracer...
    I HAVE A TAG HEUER AQUARACER ELECTRIC WATCH (BATTERY OPERATED) THAT HAS AN ALARM FUNCTION THAT I CANNOT SHUT OFF. IT GOES OFF EVERY DAY. HOW CAN I STOP THIS?
    I presume you no longer have the instructions, so I explored the Tag web site and they do not appear to offer an option to download instructions for your watch.
    The only thing I can suggest is that you go to your nearest dealer and ask for help. You can find out where your nearest dealer is by going to the TAG web site "tagheuer.com". select one of the watches and on the right of the screen you will find a menu which includes "find your nearest retailer", who will be able to help.
    Jan 12, 2010 | Tag Heuer 2000 Aquaracer Chronograph...
    Manual tag chronotimer
    This is the owners manual for the Formula 1 ChronoTimer.
    http://ww2.tagheuer.com/_documents/manuals/EI2291_en.pdf
    Sep 16, 2009 | Tag Heuer 2000 Aquaracer Chronograph...
    I am unable to return to the 0 crown Position - TAG-CAF2112
    The aquaracer has a 'screw-down' crown.  This means that the crown needs to be screwed in the reset it back to the 0 position.
    Jan 09, 2009 | Tag Heuer Aquaracer CAF2112.BA0809 Wrist...
    Best solution is to download the ORIGINAL INSTRUCTIONS MANUAL directly from SEIKO's main website:
    http://www.seikowatches.com/support/ib/index.html
    Aug 25, 2008 | Seiko Sportura SNJ007 Wrist Watch
    Watches Logo
    1,260 people viewed this question
    Top Tag Heuer Watches Experts
    Janelle Schoonover
    Janelle Schoonover
    Bruce Robin
    Are you a Tag Heuer Watch Expert? Answer questions, earn points and help others
