SOURCE: Mitsubishi WS-65713
Yes Rhonda, first you need to do a self test to show what is going on inside set. You can search threads on test or goto ctechnicians.com. This will put you in the ball park of what is going on.
SOURCE: TV shuts off
I would suggest that you guys turn the unit off when this happens, unplug the unit for 30 seconds, plug it back in, and see if this helps. If this does not solve your problem, you should call 1-800-448-2244, so a service center in your local area can be found for further assistance.
SOURCE: Set won't stay on, won't turn on
Sounds like a capacitor on the power supply is bad. Easy fix.
