Question about Vector 1 Million Rechargeable Spotlight
WHAT IS THE VOLTAGE OF MY VECTOR MODEL VEC117FS
WHAT IS THE AMPERAGE AND HOW DO I CHARGE MY SPOTLIGHT
Posted by MARY HOLCOMBE on
  • MARY HOLCOMBE Mar 29, 2012
    HOW DO I CHARGE THIS SPOT LIGHT
Jean Boniec
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 117 Answers
6 volts rechargeable battery. Check with the manufacture for a recharger for the 110v and or a car charger for your light.
Posted on Mar 29, 2012
5 Related Answers
brainyass
Brainyass Rabbit
  • 242 Answers
SOURCE: Vector Sport Spot 1,000,000 candle power spotlight
6 Volts, here is info from site.
VEC127Y
VECTOR SPORT SPOT 1 MILLION CANDLE POWER CORDLESS-RECHARGEABLE SPOTLIGHT
  • HIGH CANDLE POWER QUARTZ HALOGEN BULB DELIVERS A BRIGHT AND TIGHT BEAM
  • AREA WORKLIGHT IN HANDLE PROVIDES UP TO 15 HOURS OF LIGHT WHEN FULLY CHARGED
  • PROVIDES CONTINUOUS SPOTLIGHT USE FOR UP TO 25 MINUTES WHEN FULLY CHARGED
  • HIGH IMPACT, BREAK RESISTANT ABS AND POLYCARBONATE HOUSING
  • TOUGH, WEATHER RESISTANT AND BUILT FOR RUGGED OUTDOOR USE
  • REPLACEABLE 6 VOLT, 6 AMP HOUR, NON-SPILLABLE, SEALED BATTERY
  • LOCKING TRIGGER FOR ON/OFF LIGHT CONTROL
  • INCLUDES AC AND DC CHARGING ADAPTERS
  • INCLUDES BUILT IN HANDS FREE WORKSTAND
Posted on Sep 17, 2008
Anonymous
SOURCE: Vector power on board high intensity spotlight
Had the exact same problem. Checked the battery and discovered the red lead was off the battery. That's all it was. Works fine now.
Posted on Jun 27, 2009
John Fourteen Six
  • 2418 Answers
SOURCE: i am looking for a plug in recharger for my vector
Try wal-mart for a universal, should be 12volts dc. They come with different sized plugs to fit about anything.
Posted on Feb 27, 2010
Boneebone
  • 973 Answers
SOURCE: Need replacement battery for spotlight
You can purchase a battery from Black and Decker, they purchased Vectorlite in 2006, here is the link, you will need to enter the model #
http://www.dewaltservicenet.com/servicenet_home.aspx?AspxAutoDetectCookieSupport=1
Posted on Jun 17, 2010
CarlGlas
Carl Glas
  • 283 Answers
SOURCE: Vector 2M Pwr Spotlight replacement bulb
It takes a H3 bulb which is available at most parts stores and Wal*Mart stores in the automotive section.
Posted on Jul 29, 2010
Vector HID spotlight glass is broken
Go on line with your computer and get to the Vector spotlights web site. Request a parts list for your model.
Nov 28, 2012 | Vector 20 Million Power Series Spotlight
Users manual for VEC117FS
Please find user manual from following link.
http://documents.dewalt.com/documents/English/Instruction%20Manual/Vector/VEC117FS.pdf
Jan 03, 2012 | Vector VEC117FS 1MM Power Series Spotlight
I have a victorlite 1.5 million candle power spotlight lost charger but I have a 12 volt 1000ma- will that work??
If the voltage and tip polarity of your replacement charger matches the charging port on your spotlight, there's no reason why it shouldn't work as a substitute for your original charger. Note, however, that if your original charger was more powerful (say, 1.5 amps instead of the 1-amp charger you have here), it will take noticeably longer to fully charge your spotlight than the original charger took. it's not a problem if the original charger had a lower mA rating than the replacement in your hand--the spotlight will sip an appropriate amount of juice from the charger.
Jul 13, 2011 | Vector 1 Million Rechargeable Spotlight
My Vector model #VEC117FS has a battery that is dead and will not recharge. The replacement battery is VEC 191 according to the owner's manual. Where can I buy this battery or is it best to just buy a new...
There are many companies on the Internet that offer Sealed Lead Acid Batteries, which may be less expensive than replacing the light. I would suggest identifying the particular battery your light has and then check what's available on the Internet to make a decision on whether it is cheaper to replace the battery or the light.
http://www.batterywholesale.com/battery-store/SLA-batteries
http://www.batterymart.com/c-sealed-lead-acid-batteries.html
http://www.atbatt.com/sealed-lead-acid-batteries.asp
http://www.zbattery.com/Batteries/Sealed-Lead-Acid
http://www.planetbattery.com/product.asp?id=10
Nov 10, 2010 | Vector 1 Million Rechargeable Spotlight
I have a vector 1 mil candlepower sport spotlight haven't charged it in a while,and doesn't seem to want to charge.Does this mean the battery pack is bad?
Unfortunately the batteries lose their ability to charge when not used for an extended period of time. The light is very simple to dismantle by removing the black rubber ring that holds the lens on and then removing the screws. I believe the following battery may be the replacement you need.
http://www.batteryspec.com/cgi-bin/cart.cgi?action=link&product=313
Oct 28, 2010 | Vector 1 Million Candlepower Camouflage...
Trying to find replacement VEC 191 batteries.
This page on the Black-Decker website has parts for the VEC117FS Spotlight. http://servicenet.blackanddecker.com/Products/Detail/VEC117FS
Oct 14, 2010 | Camping, Backpacking & Hiking
My Vector Flash light is not working, I have tried to fix localy in Santa Barbara, but was unable, there is a place to send them to be fixed, my model is Sport Spot 3 million, thanks
Baccus just bought Vector from Black & Decker (Sept. 2010)
Looks like flashlight model # VEC 139BW but a different color. (Mine is White w/blue trim.) There is a battery in the top & one in the bottom, replace them at the same time. If I can find several battery stores in Buffalo you should be able to find a local battery store there.
Baccus- 877-571-2391 for main beam, area light no longer available. Try to find local distributor & save shipping charges.
Sep 23, 2010 | Vector 3 Million Candlepower Rechargeable...
How do I change the battery?
There are two ways to charge the battery on this model spotlight. However, if you do not have the wall charger or cigarette lighter plug you will need to contact Black & Decker to see if they have replacement parts. In March, 2006, Black & Decker purchased Vector Products, Inc. Since the acquisition, Black & Decker has assumed the manufacturing of all Vector products. For customer service and warranty information for Vector products, please contact Black & Decker Customer Service.
Aug 05, 2010 | Vector 2M Pwr Rch Spotlight
Dead battery
It depends on what voltage the internal battery is. If it's a 6 volt, the charging voltage will be a little higher, close to 6.5 to 7 volts. Most of these spotlights are 6 volt. New batteries can be found at Battery International: http://batteryinternational.com/spotlight-batteries-vector-battery.html
Mar 13, 2009 | Vector 3 Million Candlepower Rechargeable...
VEC127Y
Sep 07, 2008 | Vector 2M Pwr Rch Spotlight
Vector 1 Million Rechargeable Spotlight Logo
171 people viewed this question
Top Vector Camping, Backpacking & Hiking Experts
Marvin
Marvin
Lawrence Oravetz
Vernon Taylor
Are you a Vector Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
