Question about NorStar Startalk Flash 2 Phone
How to pick up general delivery mailbox messages
My General Delivery Mailbox says it's full but I don't know to how to pick up the messages. I can pick up the ones that show on the front desk phone
Posted by Diana on
4 Related Answers
Anonymous
  • 326 Answers
SOURCE: My General Delivery password is invalid.
Normal 0 To Log Into System Administration:
1. Enter Feature 983
2. The display will show "LOG", enter your login password
a. If your company extensions are 2 digits long enter "120000"
b. If your company extensions are 3 digits long enter "1020000"
c. If your company extensions are 4 digits long enter "10020000"
then
Normal 0 2. Select the softkey under "MBOX"
3. Select the softkey under "Chng"
4. Enter the mailbox number you want to reset the password for
5. The display shows "Reset Password"
6. Select the softkey under "RESET"
7. Press the release key
*The new password will be "0000", the system will ask the user to change this the first time they log into their mailbox using this password.
Posted on Aug 27, 2008
Anonymous
  • 30 Answers
SOURCE: how to chg a norstar mailbox from 'General Delivery' to 'User'
check under the mailbox set up ( where you created it) for that extension that the extension number of that phone is on that mailbox> in other words, you could create mailbox 221, but assign it to 222. The Gen Delivery box is 100 which is the catch all for transfers that cannot be completed.
Posted on Jan 07, 2009
curlycord
  • 277 Answers
SOURCE: Automated Attendant sends calls to general delivery mailbox
Make sure the set is not forwarded anywhere.
Try F#4 or F#984 to cancel any forwards.
Posted on Jul 26, 2012
curlycord
  • 277 Answers
SOURCE: Can't access the General Delivery Mailbox
To retrieve message from mailbox behind the phone:
Feature 981
Enter your password as asked
To retrieve message from mailbox that is not behind the phone:
Feature 981
Press OTHER
Log = Your ext # and password together
Press OK
Example if mailbox 100 and password 1234 then your log = 1001234
Example if mailbox 221 and password 5678 then your log = 2215678
Posted on Oct 19, 2012
Nortel phone - VM box locked contact admin - tried solutions & no luck
Hi Lyndsay,
Have you tried feature 985, and then press 9, and enter the passed resetsmppwd? That should reset the login on feature 983 to 1020000 for three digit extensions, or 102000 for two digit extensions. Once you get into there, you can reset the mailbox password for the general delivery mailbox. Depending on your system, even though the general delivery mailbox might be on extension 363, the mailbox number is likely to be 100.
Jan 04, 2014 | Nortel T7316E 2-Line Corded Phone
What's the password for meridian general vm box
How do we know? its your system.
Suggest you reset it back to default (0000).
But you need the password for Admin programming (F983).
Once your in do MBOX,CHG, 100 (or 10), RESET
Done
Dec 10, 2012 | NorStar M7310 Corded Phone
Feature 981
Feature 981
Press OTHER
Press OK
Oct 15, 2012 | NorStar M7310 Corded Phone
How can I check the voicemail, my assistant left and I don't know how to retrieve?
Where did your assistant check the voicemail? In a TVA system, each extension VM password can be reset from mailbox 999. If you don't have that password, you would have to call your dealer/installer or check their notes. If you're trying to get to the General Delivery Mailbox, it's done from the Message Manager's mailbox (998). Again, it needs notes, but I think you can reset that password from MB 999.
Carl
Aug 13, 2011 | Panasonic KX-T7633 Corded Phone
Hello i have a Panasonic KX-T7420 phone. how do i listen to the messages? thanks
Which ones? A Pana brand VM has an access code of 165. Your personal messages are in your box, the system messages (General Delivery Mailbox) are in mailbox 998. When you dial 165, you're automatically in your box. Mailbox 998 has a special access code that you dial and use to retrieve messages. We try to prevent messages from being dropped into the GDM, but it happens.
Carl
Apr 13, 2011 | Panasonic KX T7436 Corded Phone KX-T7436
My phone is Norstar M7324. I can't get voicemails. I have customers called and left voicemails but I can't receive them. I use Feature 981 and it tells me no messages everytime. Any advise? Thanks.
Maybe the callers are leaving messages in the General Delivery mailbox? From your phone, dial Feature 981, when it prompts you for a password, press the button under "OTHR", and you will be prompted for the log. (The log is the mailbox and password combination for a mailbox not assigned to your phone.) If you use 2-digit extensions, the General Delivery mailbox is #10, for 3-digit extensions, the mailbox number is #100, and etc. The default General Delivery mailbox password is "0000". So, using 2-digit ext's, the log would be 100000, then press # or OK and you can retrieve the messages. Write back if you need more help.
Mar 16, 2010 | NorStar M7324 Telephone
I am having a problem with the Nortel phone
That set may have the general delivery mailbox attached to it. The mail box number for the general delivery mailbox is 100. you might try and resetting that mailbox to see if it gives you access.
Nov 03, 2009 | Nortel T7316E 2-Line Corded Phone
Hi ..once the answer machine is activated it will not let a person leave a message, continues to say there is not enough space to leave a message, yet all 4 lines have been cleared of messages...help!!! we...
The general delivery mailbox could be the one thats full. try feature 981 press the othr soft key the display should say log:enter in 1000000 (the general delivery mailbox is 100, and defaulted password is 0000.) Hopfully the password wasn't changed
Sep 17, 2009 | NorStar T7316E Telephone
How to chg a norstar mailbox from 'General Delivery' to 'User'
Jan 07, 2009 | NorStar T7208 Corded Phone
Norstar Mailbox Problem
The mailboxes don't need to have saved messages, to be full. More then likely what is happening is that when people call in, they are getting a generic/Auto Attendant vm box, and that one is full. Try checking vm box #100, or #10. That is the Nortel standard general delivery vm box. Please let me know is this helps, or if you more help.
May 25, 2007 | NorStar M7310 Corded Phone
NorStar Startalk Flash 2 Phone Logo
219 people viewed this question
Top NorStar Lands Phones Experts
Marvin
Marvin
pbxinc
martin hogg
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
