When I try to play my sharp MD-MT15 midi dish player, it did not play. It say TOC ERRORa. Please some one help me to fix it. Thank you very much!!!
Pennywhistler
    Champion:
    New Friend:
  • 231 Answers
That's an ancient player!
Try using a different disc. Try using the external power supply.
User manual http://www.minidisc.org/part_Sharp_MD-MT15+MT16+MT20.html
Posted on Apr 16, 2014
3 Related Answers
Anonymous
SOURCE: toc error problem
HEY,
t is not the topic, but I'm for al long time searching for the sharp md-mt20h and I see that you buy a new md player? Were can I buy him?? thanx
Posted on Feb 26, 2008
otacon
Damen Wong
  • 1950 Answers
SOURCE: sharp minidisc MD-MT20 H - TOC ERROR a
I am sorry to say but your unit needs to be sent for repair. The TOC error shows up when the unit can't read the Table Of Contents of the disc (and simply shuts down after trying)....and in your case, you said it can't read any disc. This indicates that the lens unit has malfunctioned and needs to be repaired or replaced.
Posted on Mar 17, 2008
Anonymous
  • 41 Answers
SOURCE: TOC ERRORa
The TOC errors were common with Sharp Minidisc recorders. Perfect discs were ruined. Check out minidisc.org. There are lots of technical postings on this error and how to recover the TOC.
Posted on Oct 11, 2009
On a Sharp MD-MT16 what does toc error mean, and how can it be fixed?
User manual - http://www.minidisc.org/part_Sharp_MD-MT15+MT16+MT20.html
How i can fix TOC ERRORa
Table of Contents errors usually happen if you lose power before the disc is 'finalized' when recording. You cannot unplug the unit before it is done with a disc, or remove it until it is done finalizing. You will see "TOC" flash when you are done recording. When it stops, then you are all set. Try a fresh disc and see if that works.
User guide for md mt16 player
You could try looking, you know.
1helpful
Ive just got a mini disk player and its comeing up toc error,can you help me please
Probably not. There are various reasons that TOC errors occur, some are fixable and others not, but Sharp MD units were really known to suffer from them for multiple reasons all at once. TOC means Table Of Contents; it's an index file on the disc which tells the host machine where everything on the disc is located and the TOC is modified whenever you edit a disc. Sometimes the file gets corrupted, but often the machine itself simply becomes unable to read the disc and as the TOC is the first thing it tries to read then you get a TOC error.
If you're lucky the TOC error is limited to a single minidisc; if this is the case then it's just one faulty disc and although there are ways to perform TOC cloning they usually involve hacking the host machine in various ways which may cause permanent damage. Unless the disc is important, just chuck it away and use a new one. If the fault is with the player then again, just chuck it into the nearest electronic waste recycling bin. Spares are not available, and as it's a Sharp, diagnosis will be difficult and the fault likely to return.
Many MD players are practically worthless these days so they're often available on FreeCycle and Freegle groups: Sony are the preferred choice by far, and are also the most commonly offered brand, but take whatever is on offer without complaint and worry about problems later; after all, they are free.
2helpful
Kenwood MD plays ok but recordings fail to play; U TOC error?
Without a decent Table Of Contents, your MiniDisc will NOT work, as you've found out. Does it matter what brand of MD you use? I would record it at "1X" and NOT 4x speed too. Try erasing a blank minidisc first and then shut off the unit and then turn it back on and see if the TOC works. Try adding a title, then turn it off and back on. Then try the CD to MD.
4helpful
2answers
TOC ERRORa
When you FINISH recording, the Minidisc recorder Writes the TOC (Table of Contents) - so you see it flashing TOC or Update when you finish recording - you need to Leave POWER ON and have the unit on for about 30 seconds for it to finish this. IF you don't, the unit doesn't know where to find the files since there is no TOC. Try a Sony home unit - you might get one more shot at it working with that.
1helpful
MD Error Message
I'm sorry this isn't much help, but I had the same problem with my 702 unit. From what I've read it's very common with this model - Sharp claims to have remedied the error with their 831 unit. Luckily, when I had this problem, my recorder was still under warranty and I have to say that Sharp fixed it promptly and returned it to me. Have you tried contacting them? Since it's a design flaw, they might be amenable to working something out with you...
8helpful
Sharp minidisc MD-MT20 H - TOC ERROR a
Toc error problem
HEY,
Marvin
Marvin
