When i bought this laptop it was second hand due to a low budget, as i loaded up my laptop for the first time i was asked to make a backup disk, but would burn upto 99% but would not verify the disk, my CD/DVD Burner is a multi daul layer burner wich accepts all CD/DVD's, ive tried the registry edit and also a firmware update with no luck and also tried Driver Genius pro 11 but apparently my drivers are up to date...please help
SOURCE: cd dvd writer not working
ok " I would get a dvd/cd cleaner disk, has a tiny brush on it that cleans the lens in your drive.
SOURCE: wont find cd drive acer aspire 5520
If it's brand new and giving you problems already I would take it back.
Unleash Your Computers True Potential!
SOURCE: Pioneer (DVR-K17) DVD RW Burner
Hi, the error code that you have is a known issue from Microsoft that needs a registry tweaks. Error code means "Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (code 39)". You can click on this link for your reference http://support.microsoft.com/kb/929461/en-us
To resolve this problem, remove the affected filter drivers. To do this, follow these steps:1. Click Start, type regedit in the Start Search box, and then click regedit in the Programs list.
If you are prompted for an administrator password or confirmation, type your password, or click Continue.
2. Locate, and then click the following registry subkey:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
Caution There can be many instances of the registry subkey that is mentioned in step 2. You must make sure that you are in the appropriate registry subkey before modifying the UpperFilters and the LowerFilters values. To verify that you are in the appropriate registry subkey, make sure that the Default data value is DVD/CD-ROM and the Class data value is CDROM.
3. In the right pane, right-click UpperFilters, and then click Delete.
4. Click Yes to confirm the removal of the UpperFilters registry entry.
5. In the right pane, right-click LowerFilters, and then click Delete.
6. Click Yes to confirm the removal of the LowerFilters registry entry.
7. Exit Registry Editor, and then restart the computer.
Hope this helps. Good Luck!!!
Thanks
