A little sea water splashed on my camcorder and after that I have been experiencing the following problem. In tape recording mode or card recording mode, when the LCD is closed and the EVF set is extended the cam corder is getting switched off. In play back mode I am able to view in the EVF set. Please suggest a good solution for me.
SOURCE: Describe your Panasonic PV-GS35 Mini DV Digital
There was an earlier post that explained the black ribbon between the LCD viewfinder and the body of the camera is split. You would have to buy a new LCD viewfinder for about $90 or send it back to them to fix for around $250. The same thing happened to my camera and I can actually is the split. If you close it down more than half way the picture shows up. I called Panasonic and they said you have to buy the whole LCD, that you can't just buy the ribbon. They don't even have a part number for just the ribbon. Good luck.
SOURCE: My windows 7 laptop does not recognize my
You are going to have to check that your firewire is being seen by windows 7 first of all. If not you will need to rectify that.
When you do get it to recognize it, here is a link for an update to the program that came with your camcorder for it to work with Windows Vista but it should also work for Windows 7.
http://www2.panasonic.com/consumer-electronics/support/Cameras-Camcorders/Camcorders/MiniDV-Camcorders/Drivers-Downloads/model.PV-GS39.D#ts
Hope this helps,
