Question about Rheem 50 GAL ELEC TALL Water Heater 6YR SC 83VR522
I opened the top panel (thermostat panel that you have to unscrew at the top) and didn't see a red reset button, or anything that looked like a reset button. Totally confused now. Please help?
If there is no reset button, you should be able to turn the breaker off for a few minutes. then turn it back on. if its an electric water heater! it should reset it. good-day !
Posted on Mar 29, 2012
SOURCE: 12-year old Rheem residential single-thermostat
TIME TO REPLACE TODAYS ARE MORE EFFICIENT
Posted on Sep 08, 2009
SOURCE: No hot water, Rheem Model RR612T, Electric Hot Water Heater, 60 g
If you don't have current, 0v from terminal to terminal, then you don't have voltage to the elements. Replace the thermostat but check that you have 220v to the thermostat. It is possible that your breakers to the unit are either bad or tripped.
Posted on Apr 07, 2009
SOURCE: TRYING TO REPLACE MY OLD RHEEM WATER HEATER MODEL
I would say your water heater is from the fury series; new model number 82V52-2. I've included a link with my solution that you should take a look at. You could also look at water heaters of a different brand if this one isn't available in your area. Kenmore, GE, and Hotpoint are all very good brands of water heaters.
http://www.rheem.com/product.aspx?id=09DF2BDD-5E11-4D32-B574-84ACFB8A4619
Posted on May 25, 2010
SOURCE: Rheem 83xr52-2 50 gal residential water heater.
You can open the top up again. I would not turn the temp higher than 130 degrees, maximum. However, there should be above the thermostat a red button. This is where the power wires connect to the thermostats and heating elements. Sometimes this button needs to be reset, press it and discern if you hear a click sound. This means that the high temperature safety switch has tripped open and you had to manually "reset" it. There are two thermostats by the way. The water heater usually works this way. There are two thermostats and two heaters. The upper tank heater turns on first and it heats the top half of the tank. Then when the thermostat above is satisfied it then allows the bottom heater to come on and heat the bottom half of the tank. You might want to set the bottom heater thermostat as well. This is made this way because it is actually faster and more efficient to heat the top half first and the bottom half secondly. Try this first with the reset button. We could check voltages, but that requires a level of knowledge and safety that I am not sure that you are comfortable with. Pictures of the upper and lower thermostats and connections will help if the "reset" does not do the trick. By the way, not meaning or implying anything, but did you move the thermostat in the right direction? Sometimes the dials can be confusing.
Posted on Nov 28, 2010
SOURCE: Hello, I have a Rheem 81V52D 50 gal. residential
It's probably bad upper or lower thermostat.
BUT... new element could also be shorted.
OR ... original tank is rated 1500 watt elements look at label on side of tank.
I always replace both thermostats to save time.
Lower thermostat costs $10 at Lowes.
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on Jan 17, 2011
Dec 14, 2012 | Rheem 81V52D Water Heaters FOR 220 VOLTS
Sep 25, 2012 | Rheem 81V52D Water Heaters FOR 220 VOLTS
Sep 10, 2011 | RHEEM 30 GAL ELEC TALL Water Heater 6YR SC...
Aug 12, 2011 | Rheem Single Water Heater Thermostat
May 25, 2011 | Rheem Water Heaters
May 19, 2011 | Rheem 81VP6S/430126 Water Heater
Apr 09, 2011 | Rheem 50 GAL ELEC TALL Water Heater 6YR SC...
Dec 31, 2010 | Rheem 50 GAL ELEC TALL Water Heater 6YR SC...
Nov 24, 2010 | Water Heaters
May 25, 2010 | Rheem 50 GAL ELEC TALL Water Heater 6YR SC...
915 people viewed this question
