Question about Bunn CWTF 15-APS Coffee Maker
Cwtf-15 bunn water leaking at top edges
Water leaking at top edges of cwft-15 bunn coffee maker
Posted by Betty Pippin on
5 Related Answers
Kelley Hopper
  • 67 Answers
SOURCE: my bunn coffee maker CWTF-15 21604-0001
It sound like you are either missing the sprayhead or the temperature isn't hot enough. Check first to see if the sprayhead is there. It fits under the brew basket and looks like a little shower head - it's round and has usually five or six little holes in it. If it is missing your coffee will be weak due to the water not being spread across all of the grounds evenly.
The other thing to check is the temperature. Depending upon where you live the water should be between 185F - 200F. If the water is below that temperature the coffee may look like tea.
Posted on Feb 01, 2008
EsWorld
Ernest R
  • 1618 Answers
SOURCE: Bunn CWTF 15 Coffee Maker Overflowing drastically
Have you tried resetting the brew volume(make sure board is not set to lock).
The only other thing I can think of is replacing the timer board, because its not telling the solenoid to stop brewing.
Posted on Apr 28, 2009
EsWorld
Ernest R
  • 1618 Answers
SOURCE: installation of grommet on model cwtf 15 ( 1 lwr/2 upr pf
Which grommet, there are several on the bunn models, but the most commonly replaced one is the one for the P. stat. Remove the top panel there are 2 screws one in front and one in back, then lift the top 2 burners off machine that will give you access to the tank.
Posted on May 04, 2010
atbsmmom
  • 189 Answers
SOURCE: my bunn coffee maker is leaking water out of the
Please get the model and code date located on the bottom of the brewer. The machine has a 3 year warranty and if it is 3 years old or less, it will be replaced at no cost. If it is older than 3 years old, it will be replaced at a discounted price. Once you have this information please call customer service.
Posted on May 19, 2010
atbsmmom
  • 189 Answers
SOURCE: Bunn coffee maker leaking from underneath the bottom
Please get the model and the date code from the bottom of the machine and contact customer serivce. Depending on the date code, there might be a seal kit available or the machine can be replaced at no cost if 3 years old or less. If it is over 3 years old and the seal kit isn't available, the machine will be replaced at a reduced price.
My Bunn CWTF-DV-3Tisleaking water from the top right corner of my machine,and has just started leaking at the base of where the bottom burner is. Could you please help,as we have no technicians were we...
open the top. there is a trough drain that gets limed up. using a phillips head screwdriver, push through and twist, thereby removing the lime and ensuring proper flow. if water can't get through, it may overflow over the sides of the trough. also look behind the trough to the top of the tank and see if there is any water damage around the seals. if there is, replace the seals
Feb 17, 2014 | Bunn CWTF 15-3 Coffee Maker
Water is not hot when turn on
check the heat switch in the rear. if it's on, check the thermal fuse in the top right rear of the brewer. it'll be in a now browned tubing. you can get it through bunn (800) 352-BUNN (2866)
Jan 05, 2014 | Bunn CWTF 15-APS Coffee Maker
Water not coming out of hot water spigot
thermal fuse is blown. it is located in the top, right rear of the machine in what is now browned tubing. you can either bypass the fuse with a jumper, or get a new part through bunn (800) 352-BUNN (2866)
Dec 10, 2013 | Bunn CWTF 15-APS Coffee Maker
Water leaking from the top
open up the top and check the trough drain for lime. if it is obstructed, the water will overflow. use a screwdriver and poke it through the drain
Nov 07, 2013 | Bunn CWTF 15-APS Coffee Maker
I need to ship a 3 burner BUNN CWTF 15-3. How do I drain the water out?
You can take the lid off and unscrew the nut that holds the water tray. Then take a 3/8 hose to siphon the water out of the machine.
Apr 17, 2013 | Bunn CWTF 15-3 Coffee Maker
Bunn CW series slow water flow
delime the sprayhead and the reservoir drain in the top with a deliming spring or a screwdriver
Dec 03, 2012 | Bunn CWTF 15-3 Coffee Maker
Cwtf is a contant dripping from the dispenser funnel, how do i fix this?
Inlet valve is leaking.Valve is located by removing front access panel.Can be rebuilt using p.n. 1111.0002 repair kit.You can verify by removing top lid and finding water leaking at fill basin tube.
Dec 27, 2010 | Bunn CWTF 15-APS Coffee Maker
Installation of grommet on model cwtf 15 ( 1 lwr/2 upr pf
Apr 30, 2010 | Bunn CWTF 15-2 (1 Top Warmer) Coffee Maker
Our Bunn CWTF15 three burner is over filling. What can we do to correct this problem?
There is a timer inside the front panel re-just the timer with an empty coffee pot right up to the top edge with water only.
if not successful let me know and I'll go further with your problem.my email address [email protected]
God Bless have a nice day.
Dickson
Jul 02, 2009 | Bunn CWTF 15-3 Coffee Maker
Bunn CWTF 15-APS Coffee Maker Logo
148 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
Kelley Hopper
gbob59
Marvin
Marvin
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
