SOURCE: I dropped my computer and now I get error An unexpected I/O error
Attempt to Re-Install Windows (most likely this will not work) if it does not then you need a new drive. The insides of the harddrive have shifted
SOURCE: Need Wifi driver for dell inspiron 1318 (XP)
Wow, they dont write it for XP. I really think you're out of luck.
SOURCE: Dell Inspiron 1420 Factory Setting Recovery
back up all your files first because everything will be wiped out.
Turn on machine, Put the recovery cd on the cd rom drive, before it boots to windows hit the F1 to go into bios, on the startup set the cd rom the primary to boot machine on cd then follow the instructions from there..
SOURCE: i recently reformat my inspiron 1420 dell laptop
I found this site in the first shot. Just go to google search and search for the driver that you want. And if you fail to do it then go to http://drivers-download-driver.com/tag/nvidia-geforce-8400m-gs-rev-a03. Start using google for such searches.
SOURCE: DELL INSPIRON 1420 BCM2045 INSTALLATION DRIVER
http://support.dell.com/support/downloads/driverslist.aspx?c=us&cs=555&l=en&s=biz&ServiceTag=&SystemID=INS_PNT_PM_1420&os=WLH&osl=en&catid=&impid=
from here download the bluetooth driver..
The BIOS may require flashing when an update is available or when replacing the system board.
The File Download window appears.
The Save In window appears.
The file downloads to your desktop.
The file icon appears on your desktop and is titled the same as the downloaded BIOS update file.
