Question about Dell PowerEdge Computers & Internet
When the server reboots he stops with a Fan Error and aks for pressing F1 to continue. How can I avoid to press F1 and having an automatic reboot w/o problems.
Posted by Uli Schweizer on
Shawn DuRee
  • 356 Answers
You would need to replace the fan that is bad.
Posted on Mar 28, 2012
5 Related Answers
Anonymous
SOURCE: ML530 Startup
Check your Hardware configuration.  This usually happens when you tell the system BIOS that you have for example, a second floppy or Hard Drive, when you do not.  So it stops and asks you what to do next.
Hope that helps.
Eddyfix
Posted on Oct 16, 2007
Leonardo Nogueira
  • 39 Answers
SOURCE: Proliant DL380 G4 server occasionally rebootes.
Try to update the firmwares. Maybe the threeshould of the fans are incorrect. A new firmware can correct this problem.
Let me know if this post helps
Posted on Dec 17, 2007
Anonymous
  • 47 Answers
SOURCE: 02A2: BMC System Event Log(SEL) Full
In HP prolliant server sets, setup also logs system events. This error is due to that log. Enter setup, trace log and clear all events.
Posted on Jan 28, 2009
Anonymous
  • 101 Answers
SOURCE: server error
Clear System Event Log thru CMOS setup or the management software provided with server . The SEL is full that is the reason the error message
Posted on Mar 02, 2009
Anonymous
  • 60 Answers
SOURCE: dell poweredge 2600 server recently
Did you experience a power event? Go to BIOS (F2), and make sure that RAID is Enabled. If RAID got turned off (power event, BIOS reset), then it will give you that message. If RAID is already enabled, then you may need to repair your operating system. If something else happened (drive failures, drives removed, etc.), then the array may be completely gone. Call Data Recovery services if it is critical you retreive the data.
Posted on Aug 14, 2010
Hello, I went into my bios settings and did something wrong now when I start up my computer it takes me to the mi bios megatrend screen at the bottom of the screen says driver bad press f2 to resume f1...
go back into the BIOS by pressing F12 and look for the set BIOS to default values or something along those line. save those settings and reboot..
Please give feedback...
Dec 18, 2012 | Lenovo Computers & Internet
I have an Optiplex GX 620 Mini Tower that displays a NIC failure error at boot. The error message reads "NIC failure. Press F1 to reboot or F2 to go in to setup." The PC did not boots
it means your hard disk is not detected by system, check all connections of hard disk, if problem remains check with another working hard disk
Jul 29, 2012 | Dell OptiPlex GX260 PC Desktop
Logical drive has been disabled due to possible data loss
Replace the HDD whose led is blinking in AMBER ( orange ) colour.
Mar 11, 2012 | HP Compaq ProLiant DL380 G4 Server
When i on my system its start windows and stop and shows hdd error press f1 continue press 2 del f1 i press its booting failed
Your Hard Disk Drive is crashing or has crashed. You need to buy a new hard disk drive, and then you will have to reinstall windows and start over.
Jan 27, 2012 | Mercury Computers & Internet
My daughters desk top computer will boot up when I press f1 and then it shuts down and brings me back to a black screen and tells me to hit f1 and reboots. When the windows does come up I dont have time to...
Remove the battery from the motherboard and check that it has 3volts or above. if not then replace it. That will cure your pressing F1 to continue all the time. As for the restarts then you will need to turn off Automatically restart in the control panel,system section. To do this you will need to boot into safe mode. Tap the F8 while booting until you get a black screen with white type on it. Its first option is to boot into safe mode. hit enter on this screen and windows will start with no drivers loaded. the screen will appear very large. navigate to the control panel as mentioned above and untick "automatically restart". Ok that and reboot normally. now you will most probably get a blue screen of death. note the first stop code. it will appear something like 0x000000??. Its the last two digits that are the clue to why this is happening. Google the stop code and you will now know why this is happening and do something to stop the problem.
Aug 28, 2011 | Dell Inspiron 530 Desktop Computer
Hi Everybody, My server Power Edge 650 asking to press F1 during every startup. How to get rid of this. Thanks Ezhilmani
Hi There.
Symptoms
* cmos checksum error messages
* error with date time error
Solution
* Replace CMOS battery.
Procedure
1. Locate your CMOS battery.
2. Turn of your Desktop.
3. Remove the power cable from your Desktop.
4. Press power button to discharge your Desktop from electricity.
5. Desktop should be laid down horizontally.
6. Remove the battery and avoid forcing.
7. Replace the battery with same model or equivalent.
8. Put the new battery firmly in the allocated slot. (Positive side should be visible).
9. Plug the power cabe and start up your PC.
10.Enter Bios by pressing DELETE or F2 and load defaults save and quit, it will reboot automatically.
11.Enter Bios modify settings save and quit.
12.The End
Hopefully this information helps.
Thank you for using FixYa.
Jul 19, 2011 | Dell Poweredge 650 - P4 3.0GHZ, 1GB/40GB...
Problem rebooting Dell PowerEdge Server 2600
ERROR 02A2: BMC System Error Log (SEL) Full
press F1 to continue or F10 to enter BIOS.
I wait for 2 minutes without doing any thing my server get started normally.
Please help me how to stop this error
Feb 19, 2010 | Dell PowerEdge 2650 Server
Bootup Problem.
Try getting BIOS access by pressing F2. Then try rebooting.
Jun 05, 2009 | Dell /Poweredge 6650 BackPlane 2+3 Board...
Computer fan is to loud
Do the following:
Reboot your computer.
As it reboots, press the F1 key
When it goes into your bios, look through there until you see a page that allows you to control the fan speed.
change the fan to run more slowly.
Press F10 to save and Exit.
Nov 22, 2008 | HP Compaq Presario 2500 HP Pavilion ZE...
ML530 Startup
Hope that helps.
Eddyfix
Oct 12, 2007 | HP Compaq ProLiant ML530 Server
Open Questions:
Computers & Internet Logo
336 people viewed this question
Lee Hodgson
Lee Hodgson
efs_perpends
efs_perpends
Michael Thomas
Michael Thomas
