SOURCE: Dell XPS M1330 PC Notebook can't connect to the external monitor
No. You just basically need a VGA cable. Check your video settings.
SOURCE: i have dell xps m1330 bios password
If u know the password put it if u dont know it just format u laptop I think that there isn`t any other solution....
SOURCE: time-of-day clock stopped on dell xps m1330
When you alter the Date and Time and next time you boot up again the date and time has reverted back to some other time, this indicated the BIOS battery is flat and it needs to be replaced.
To fix this problem, replace the BIOS battery and change the date and Time setting.
SOURCE: Dell XPS M1330 battery not detected!
Normally the life time of a laptop battery is 300 cycles. that is 300 discharges and charges. Since your laptop is almost 2 years old, the battery could be at the end of its life time, and again depends on how often you use your laptop in a day. Better goto a service center or get a similar battery from any of your friends just to make sure it is not a motherboard issue. Then you can think about which part you've to replace.
Please come back and rate my solution if it turns to be helpful fro you, or also if you need more clarifications.
Thnx
SOURCE: how do i restore my Dell XPS M1330 back to factory
Try either F8 or F11 keys
or CTRL and F11 together at start up
