first insert the cd and then go to my computer and then right click open to F drive and go to crack and copy the file in it and then go to your desktop and then right click to the cricket 07 icon and select properties and select find target and then paste it on that folder and then enjoy the game.
You need to do a complete uninstall since most uninstall programs leave lots of junk behind and fool the computer into "thinking" that the software is still installed.. See if manufacturer has software available (EX - Norton has sit) that does a complete uninstall. If not you will have to get brave and to into the registry using regedit to remove all vestiges of the program and then reinstall it. Good luck.
Or try a system restore point that was generated BEFORE the date of your original install of the program!
Issue
After installing the all-in-one and restarting the computer, the following Generic Host Process for Win32 Services error message displays:
Windows has shut down a process for Win32 services: Data Execution Prevention - Microsoft Windows To help protect your computer, Windows has closed this program.
Solutions
The following solutions should be tried in the order they are presented. If the first solution does not correct the issue, proceed to the next solution; if that solution does not correct the issue, proceed to the last solution.
Solution one
Uninstall and then reinstall the software using the following procedure:
Uninstall the software by inserting the software CD that came with unit into the CD-ROM drive on the computer.
NOTE:
If the startup screen does not appear, double-click the My Computer icon, then double-click the CD-ROM icon where the all-in-one disc is inserted. Choose the Uninstall option. If the Uninstall option does not display, the software is not completely installed. Proceed to step 2.
Install the software by inserting the software CD that came with unit into the CD-ROM drive on the computer.
NOTE:
If the startup screen does not appear, double-click the My Computer icon, and then double-click the CD-ROM icon, where the all-in-one disc is inserted. Choose the Install option.
Run the Software Update from the HP Director and apply all patches.
Solution two
Uninstall the all-in-one software using the CD that came with the unit, by following the steps in Solution one above.
After the software is uninstalled, restart the computer.
Install the all-in-one software by following the steps in Solution 1 above. After installation is complete, verify that the unit works correctly.
Change the Windows Image Acquisition (WIA) service from Automatic to Manual by performing the following steps:
Right-click My Computer , then select Manage . The Computer Management window opens.
in the Computer Management window, click the plus ( + ) sign next to Services and Applications .
In the list below Services and Applications , select Services .
In the right-hand side of the window, right-click Windows Image Acquisition .
Select Properties .
Change Startup Type to Manual .
Click OK .
Close the Computer Management window.
Add hpqtra08.exe to the Windows Firewall Exception list by performing the following steps:
Click Start , then Control Panel . (Click Start , Settings , then Control Panel if you are in Classic Start menu mode).
