The ink and paper light flashes together signalling that something is obrstructing the print head. These lights come on as soon as I turn the printer on thus not allowing me to do anything with cartridges and such. There is absolutely nothing in the way, and there aren't any odd noises when I turn it on. What could be casusing this error?
SOURCE: Epson CS3200 - Non-specific power-up failure & error message
Please go to my website http://www.the-inkstore.co.uk . I have the latest version of SSC Service Utility to download directly onto your computer and instructions on how to use it, what to click on etc etc. Click any of the Epson links if you can't find it, everything you need to know will be there, including printer Firmware resetting which sorts out a multitude of problems.
The 'maintenance required' problem with Epson printers has absolutely nothing to do with which cartridges you are using, it is a built in page counter in your printer firmware, which has a different maximum amount for each Epson model. Don't listen to old wives tales and heresay, we are the experts and it's an Epson scam to cause a lot of people to pay for maintenance or throw their printers away.
I haven't found a model that can't be reset with the latest version of SSC Serve or the manual reset on my site.
For Epson RX500 users there is also a manual reset on my site, as the SSC Serve software won't do it for you.
When using the program & choosing your printer from the list, it may have a weird name with 'x' in the model number, this is because some configurations are for many models in a series. For example, the C46 will be listed as C4x as it is for the C42, C44 & C46 models.
I hope this helps all Epson users to overcome the Epson scam of page counting and locking out until you pay their dealers money for maintenance.
If you like what I've done for Epson users, please show your appreciation by spreading the word and perhaps buying your ink from my site.
Happy trouble free printing
The INK Store (UK & Europe)
SOURCE: MY EPSON D88 PRINTER HAS 2 FLASHING LIGHTS
This is usually caused by a problem with the chip(s) on the new cartridge.
Check that the chips are clean, and are correctly installed on the cartridge(s) (some can be knocked out of alignment and thus not connect properly).
Also check for any damage to the tiny wires in the printhead where the cartridge sits.. These can also become soiled with fluff, etc... Be VERY careful if you try to clean these as they are very delicate and if broken off you will have a broken printer.
Last thing is of course to check you have the correct cartridges... A common one with the D88 is to have C86 cartridges which are not compatible at all (different' chips!).
Hope that helps.
SOURCE: both ink and paper lights are flashing, printer
the waste ink tank beneath the printer is full. it will cost more to fix this than a new printer. take a look at the Epson NX and Workforce series and get yourself a good printer with a year fedex replacement warranty.
SOURCE: The feed indicator light and
Lights flashing alternately means that your printer's waste ink pad is saturated. It needs to be replaced and reset the counter. To reset the waste ink pad counter you will need a resetting program. You may download it by going to this link:
http://www.divshare.com/download/1140953-256
First goto web site http://www.fixyourownprinter.com/forums/inkjet/50817
Read through ALL the cries for help and the answers.
Towards the end there are some very significant points, 'are the light flashing together' or 'are they alternate'
What it comes down to is you have a DIRTY printer. Don't worry ALL printers get dirty. You have to clean excess ink, and all the sensors as described in the lists from http://www.fixyourownprinter.com/forums/inkjet/50817
Regards
Remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and connect the Printer to be detected and installed. Check printer properties to see the ink levels.
Use head cleaning before a test is taken . It is possible that the head is not reacting to the need of the command , can be an issue with ink drying , can also be poor ink cartridge contacts.
