Question about Marantz SR7005 Receiver
Marantz sr7005 reset unit - Marantz SR7005 Receiver
1 Related Answer
Anonymous
  • 8546 Answers
SOURCE: Hi There, I have a
It sounds like you've read one of my many posts on 901 deployment in the AV world.
Functionally, what is the difference between one amp with 'x' channels or 'x' mono amps? Nothing. Pre-outs don't know or care what else an external amp does.
According to this link http://www.ecoustics.com/electronics/products/new/642968.html those amps are 2- and 5-channel, respectively.
There was a time when I had two bridged-mono Carver Cube atmps (at a real 400 watts) pushing one 901 each but that was big time overkill.
I now use a Carver AV-406 (functionally the same as your MM7055) with the 901 EQ in between the AV Receiver's front pre-outs and two 110-watt channels. Other channels on the AV-406 pull subwoofer and surround back duties. My AVR directly powers only the center and surround speakers.
The MM7025 would work for you.
Posted on Jul 07, 2011
2answers
All of a sudden stopped working and won't turn back on. been 12hrs. when power is pressed, it turns on for 2 seconds and then standby lights blink again and it turns off
This could be caused by a direct short circuit on the speaker outputs. Try disconnecting all the speaker connections at the back of the receiver and then power back on. You can also try a factory reset by holding the surround mode + clear button for 3 seconds.
Marantz SR7005 not working.
I have the same receiver SR7005 and the HDMI board went out. The boards are on back order and weren't expected to ship for a month or so. Magnolia, the store where I purchased it gave me a new receiver. I think they might be having issues with this board. The board went out on 4/30/12, just got my new receiver 6/21/12. I have a feeling that this will happen again and others will have the same issue. All you need is a new HDMI board, the processor went out in it.
Maranz sr7005 no sound
Most of the time no sound means fuses have blown or output transistors
How do you reset a marantz
Hello
All details about reset and other functions and adjustments are with its repair book. I've the repair book, but I can't send it to you by this window as this window does not allow me to upload PDF files by it. The book is in PDF format, having 205 pages and have 20.5MB in capacity.
If you are interested to get it, you have to buy one among my audio services published at Fixya, and by send your email address to me by that window. You ac also access my services by searching at Google. Tyep in 'gopakumar gopalan - profile - fixya' at Google search baox and press enter. Click the link and you can see all of my services advertised at Fixya there. Choose an appropriate one among them and send your email address to me by the window appears. I'll send you both the user manual and repair book to you by return mail. OK.
Hi There, I have a Marantz SR7005 Receiver and Bose 901 Series VI speakers with the Bose equalizer. I'm struggling to figure out the best way to connect the Bose equalizer/speakers to the SR7005. ...
No image, only sound when connecting marantz sr 7005 hdmi out to hdmi in on tv philips 47pfl9632d
Whatever video components you have, they should be, depending on inputs on TV, should be run to TV first. Recievers do have pass through ports but, are not the best way to achieve picture and sound. HDMI cables are great but you r reciever may not be able to transfer the video. What I suggest is taht you run your componenets, cable/sat box, DVD, etc. via HDMI, componenet, etc., to TV input, then, run audio out from TV, via(best) digital optical. You can use TV's menu to choose what you watch while, you only have the one input to reciever. Scan your recievers menu to make sure you have selected the proper mode(TV, Aux, Vid2, etc.).. If you run your video unit to TV with component cables, you will have to get your sound through separate cable(s). Component cables have graet video, but do not carry the sound.
Hi, I have recently purchased an SR7005 which is connected to an HD PVR via Audioquest Cinammon HDMI cable. While watching programs, I lose audio immediately after an advertisement break. If I pause...
If you are watching adverts that implies a broadcast TV sound signal. What happens is that the broadcaster will switch off sound especially Dolby signals during add breaks. Therefore it could be your TV that stops sending the sound to the Marantz. So check the sound settings of you TV. It might have an auto feature that detects the signals, that could be switched to manual or just a wrong sound signal that causes the problem.
My sr 7005 loses a signal for 2 seconds when watching a bluray or cable
It takes two, maybe more to tango - plus the cables that carry the various signals.
Can you define the signal loss better? Where do you detect it?
Audio, video, both?
Optical, HDMI, component ????
Try a different input or output port on the Marantz to isolate the source(s) as contributors.
Need PDF User Guide
Hello
Send your email address to me by Fixya comment. I've the user manual to your device in PDF format. I'll send a copy of it to you by return mail. OK.
Open Questions:
See all Marantz SR7005 Receiver Questions
Marantz SR7005 Receiver Logo
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
