Question about Sub-Zero 642
LCD panel and lights not working
Complete shut down after a bit. Unplug for a while then plug in and turn on, the machine starts and runs, but no lcd panel or ref lights, freezer lights work, then shuts down
  • Dwight Everlith Mar 27, 2012
    Freezer works fine, no LCD or lights in fridge, working fine still cold. But no control lights or interior lighting in fridge
    Passionate:
    Visited the website for 10 consecutive days.
  • 114 Answers
On your Sub-Zero 642 Your display will not work unless your refrigerator lights work.
1st. Make sure your light bulbs are good.
2nd. Check your refrigerator door light switch.
3rd. The subzero uses a thermal overload to kill your lights if the door is left open to long.
http://www.on-timeappliance.com/subzero.html
Posted on Mar 27, 2012
3 Suggested Answers
6ya staff
SOURCE:
Anonymous
  • 151 Answers
SOURCE: sub-zero 650 freezer gets too cold (-18). freezer
sounds like it could be a bad thermostat on the unit.
Posted on Dec 26, 2009
benham
  • 125 Answers
SOURCE: Hello. We moved into a house a year ago that had a sub-zero fridge/freezer. When we go on vacation, the freezer unit sometimes shuts off (from not being used??). To get it working again, we have to tu
It sounds like it may be the thermostat. turn it down to a normal level and give it a good tap to see if it starts. you may need to leave the door open so it warms up bit so it will start, it wont start if its cold as the thermostat would be satisfied. If it does start the thermostat should be replaced. I hope this helps
Posted on Apr 18, 2009
Power and opc bottom blinking, tv won't come on
Sharp LED/LCD EEP cleared Step 1 Remove Mains Plug 2 Press On/Off Switch from LED/LCD Panel 3 Press Ch Down & Input Switch together and plug in mains cord 4 LED/LCD will start 5 "K" will appier on Screen 6 Press Ch Down & Vol Down from LED/LED Panel 7 1/9 Page will appier on Screen 8 Go to 9/10 page by pressing Up & Down arrow of remote 9 Select EEP Cleared 10 Press ok button from remote 11 On Screen dispay EEP running 12 Remove Mains Plug after complete EEP Run 13 Restart LED/LCD
Jan 08, 2016 | Sharp Televison & Video
Tip
HOW TO REPLACE ACER LAPTOP LCD SCREENS
READ CAREFULLY FIRST BEFORE STARTING
Removing the screens bezels will void warantee
In Saying that ,
Heres how I would do a screen replacement,
You will need a small philips screwdriver for this ...
Remove the power and battery
To Remove the bezel from the front of the screen
There should be 4 or 6 screws holding the cover on,
Screws may be covered by rubber buttons,
then remove the screws holding the LCD to the hinges' frame.
Tilt forward your LCD and lie screen on your keyboard
LCD panels have a row of IC chips at the top that produce the images on your LCD so do not touch or flex this area because it may produce lines on the LCD or kill it completely.
botom of screen is inverter power and plug to screen
top rear of LCD is video feed from motherboard,
(above that are those important IC Chips-
DONT TOUCH THE CHIPS)
LCD wiil have tape fastening plug to the socket,
Remove tape and this will expose the plug.
Un plug from screens socket,
Reseat plug back into socket,
Put Tape back on to stop any unwanted movements,
Next step is to power up the LCD to test.
Rest LCD in back of lid and lie lid on table with base at 90 degrees for access to plug in AC power.
do not use battery for this test.
Turn ON power,
If it starts up, then you have a running machine again,
Shut down , unplug power and reassemble,
If LCD does not start then you need to replace the LCD panel and thats about all you can do,
Hope this helps.......
Cheers MisterdJ
on Apr 12, 2010 | Computers & Internet
Magnavox television won't stay on
I know this is going to sound strange but I have something to check. If you have LED lights in your house turn them all off. When they are off turn on your TV and see if your TV stays on. Yes, there could be many problems but this one is cropping up quite a bit. If this does not work then you need to take a look at the power supply board.
Feb 15, 2015 | SNK Magnavox 42MF438B/27 42 in. LCD TV
I have a sharp aquos lc-c4677un its not turning on at all now. When I push the power botton on the tv, the power light turns on and about 2-3sec the power and opc light start to blink and thats about it.
How are the power and opc lights blinking? Do they blink simultaneously or does one blink then the other? How many time do they blink per second? Also have you had it fixed yet? and if so what was done? I had a similar problem with my set.
Aug 06, 2011 | Sharp AQUOS LC-C4654U 46" LCD TV
Hi, i have a problem with my lg 32" ld350 tv..it
Hello.
This is a thermo-related issue. It happens when some parts in your TV reach certain temperature and fail creating short so TV shuts down and goes into protection mode.
In your TV the only thing that you can do is to replace Power Supply and hope it would help. Main board generally has nothing to do with temperature. Another probability - LCD panel itself (more likely back light inverter boards that are part of the panel, you can't order them separately).
There is inexpensive way to determine if it is power supply or not. You have to purchase fast-cooling spray that technicians use for diagnostic purposes (you can buy one in electronics components store).
You have remove TV rear cover so you have access to power supply board (the one where power cord goes). Turn on TV and let it run and eventually shut down. After that unplug it from wall outlet and use spray to cool down power supply board. Make sure you don't spray too much or you cooling anything else besides that board!. Let residue evaporate and plug TV back and try to turn it on. If it act OK and stays on for long time again - replace power supply and you should be OK.
Otherwise it is time for new TV. Panel is too expensive to replace.
Regards.
Russ.
Dec 01, 2010 | LG 32LD350 32 in. LCD TV
My Sharp LC-42-D62U won't power up. The power light blinks twice, then the power light and the OPC light blink together once. any fix to this problem?
Ur Tuner signal board have problems or dead.Ur power LED light indicator stable for a few mins before the power LED light,and the OPC LED light indicators flashes?After the POWER light and OPC light indicators flashes,just push the power button again for the power recycles again.Probally have to pushes the power button 3 or 4 for power light and opc light indicators flashes,the LCD backlght will lght up and work.Sharp tv have this problems alot,very common in Sharp LCD tvs.
Apr 17, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
My Sceptre LCD TV (X32GV-Komodo0 power turns on
1. check power supply
2. check flyback
Ether or you have a ppower fauilure in the unit. and its probably blowing fuses.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Aug 31, 2009 | Sceptre X32GV-Komodo 32 in. LCD Television
Thinkpad lcd wont come on
Hello, It may be the power is set wrong. Click start, control panel, power options. From here you can set the amount of time you want the monitor or hard drive/s to remain on until the shut down or go into hibernation. Hope this helps.
Mar 25, 2008 | Computers & Internet
Lcd tv shuts down by its self
All you need to do is remove the back cover, then remove the metal cover that covered the power supply. Watch tv w/o cover, it won't shut down again. Try it and post here if it works.
Sep 12, 2007 | Televison & Video
Refrigerators Logo
621 people viewed this question
Top Sub-Zero Refrigerators Experts
John Tripp
John Tripp
louis_benton
Level 1 Expert
DOUG DYKAAR
DOUG DYKAAR
Level 1 Expert
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
