Question about Texas Instruments TI-84 Plus Calculator
Fix the ERR:INVALID DIM message on my TI-84 plus, please.
When trying to get the parabola graph, after entering the euation with the y= key, on pressing GRAPH key, I get the error message. Help!
Posted by pat thiesen on
Stevan Milanovic
    Sergeant:
  • Texas Instru... Expert
  • 267 Answers
INVALID DIM error message may occur if you are trying to graph a function that does not involve the stat plot features. The error can be corrected by turning off the stat plots. To turn the stat plots off, press 2nd, STAT PLOT , and
then select 4:PlotsOff.
Posted on Mar 26, 2012
Testimonial: "Once I located the STAT PLOT key and selected 4, it worked like a charm. Thanks so much. It saved me $35 that another site would have charged me."
3 Related Answers
  • 102366 Answers
SOURCE: Not Graphing
You're probably trying to graph a function that does not involve stat plot features. You can correct this by turning off the stat plot features. Press "2ND" "STAT PLOT" and then select 4:PlotsOff.
If that's not it, post a comment and we'll go from there.
Posted on Apr 08, 2010
  • 102366 Answers
SOURCE: Whenever I try to graph something on my TI-84 plus
Posted on Sep 09, 2010
  • 102366 Answers
SOURCE: i want to graph a
You're trying to graph a function that does not involve stat plot features but the calculator probably thinks you are. You can correct this by turning off the stat plot features. Press "2ND" "STAT PLOT" and then select 4:PlotsOff.
Posted on Oct 29, 2010
Mar 26, 2012 | Texas Instruments TI-84 Plus Calculator
How do I get rid of the ERR: INVALID DIM message?
You're trying to graph a function that does not involve stat plot features. You can correct this by turning off the stat plot features. Press "2ND" "STAT PLOT" and then select 4:PlotsOff.
Im trying to graph inequalities on my ti 84 plus, and it keeps saying ERR:INVALID DIM. how do i fix it?
Try deactivating the Statistica plots.
Press [2nd][Y=] to enter Stat Plots. Press the PlotsOff menu option.
Sep 21, 2011 | Texas Instruments TI-84 Plus Calculator
Every time I try to graph on TI 84 it says ERR: INVALID DIM 1:QUIT I have enterered something simple y= x+2 and window is set for -10<x<10 and -10<y<10 the curser in y=...
Go to http://education.ti.com/downloads/guidebooks/graphing/84p/TI84Plus_guidebook_EN.pdf to download the manual. On page 401, you will find the following:
INVALID DIM • The ERR:INVALID DIM error message may occur if you are trying to graph a function that does not involve the stat plot features. The error can be corrected by turning off the stat plots. To turn the stat plots off, press y , and then select 4:PlotsOff. • You specified a list dimension as something other than an integer between 1 and 999. • You specified a matrix dimension as something other than an integer between 1 and 99. • You attempted to invert a matrix that is not square.
Nov 11, 2010 | Texas Instruments TI-84 Plus Calculator
I want to graph a parabola on my ti-84. i entered the equation in y=, and then i turned on plot on, then i hit graph, but it is showing invalid dim. help please?
Oct 29, 2010 | Texas Instruments TI-84 Plus Calculator
Getting ERR: INVALID DIM when pressing the Graph button
If the message appears when you try to graph functions deactivate the statistical plots. To do so:
Press [2nd][Y=] to access (STAT PLOTs)
Select [4:PlotsOff] then [ENTER]
That should solve your problem. Post a comment to this thread if you still have trouble graphing.If the message appears in another context, it sure would help knowing the context of the error.
May 12, 2010 | Texas Instruments TI-84 Plus Calculator
Im getting an err: invalid dim on my TI-84 Plus calculator...what do I do?
Apr 18, 2010 | Texas Instruments TI-84 Plus Calculator
Not Graphing
Apr 08, 2010 | Texas Instruments TI-84 Plus Calculator
When trying to graph anything, ERR: INVALID DIM appears..
The easiest and quickest way to start graphing is to reset the RAM. Press [2nd][MEM][7:Reset][1:All Ram][2:Reset], then [CLEAR] to clear the RAM Cleared Message and go to the main screen.
Hope it helps.
Oct 07, 2009 | Texas Instruments TI-84 Plus Silver...
Graph and trace buttons don't work
This is probably because you have the stat plot on. You would need to go to y= and then go to the top where it says stat plot 1 and un highlight it if it is highligted. That should fix your problem.
Sep 16, 2008 | Texas Instruments TI-84 Plus Silver...
Texas Instruments TI-84 Plus Calculator Logo
1,607 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Paul Bade
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
