Question about DISH Network 625 Duo DVR Receiver (Remanufactured)
Dish network error 004
Always getting error code 004. I have unplugged the DVR. I have reset the DVR. I have manually set the signal. Still getting error code 004
Posted by Tim Terzich on
Joie
    New Friend:
I have 6400 receive. I checked my signal strength and i have 89% signal, when I press guide I can see all the guide listings but when I press the channel I get black screen and an error 004. Can someone please help me....
Posted on Sep 13, 2013
  • dish
    dish Sep 15, 2013
    Joie, I can check out what is going on. On the message, is there a signal code anywhere? It may look like 11-12-11 for example.
  • dish
    dish Sep 15, 2013
dish
  • Official Brand Answer
  • 263 Answers
Hi there, Tim!
It's possible the dish may need to be repointed. Try running a check switch test. Go to Menu > System Setup (6) > Installation (1) > Point Dish (1) > Check Switch > Test. This will provide more info on the satellite signal.
If you have run that test and the problem continues I would need to see about getting a tech out. If so, you can send me an email at [email protected] for further assistance!
Tommy Faust
DISH Social Media Representative
Posted on Mar 31, 2012
Error code 024 on guide
Hi there! My name is Kimberly and I form part of the Social Media Department with DISH. It is my pleasure to help you. Please perform a hard reset on the receiver. To do a hard reset, you simply unplug the receiver from the power outlet it is connected to, leave it unplugged for 20 seconds, then plug it back in. The receiver reboot process takes about 5 minutes. Once the show is back on, try accessing your DVR again, if it is still not working, the receiver will need to be replaced. If this is still a problem, please feel free to email me at kimberly.escobar2dish.com with your account number so we can get this resolved.
Kimberly Escobar
DISH L.L.C
Apr 18, 2014 | DISH Network ViP 922
Error code 04ee on Dish network 722 vip HDD,
Hello this is luke. I do not know of any 04 ee error code on dish network. The closest will be 004. Try to check if it is coming from the receiver or from the tv by unplugging the receiver from wall outlet while tv is on. If the code stays, then it is from the tv, if it goes away with the lights on receiver, it is from the receiver. Let me know.
Jan 23, 2011 | DISH Network ViP622 DVR DTV Receiver /...
Just on certain shows the DVR is not recording and when I go back to watch the show, It says the time that the show is supposed to be and then Error Code 4. and the screen is black. How can I fix this??
Hello, my name is Matthew Gonzales with DISH Network customer service. An error 004 is very closely related to signal issues. If you are still having this issue there are a couple things you can try if you have not. First, unplug the receiver from the power outlet it is connected to, leave it unplugged for about 20 seconds, then plug it back in. Your receiver goes through a rebooting process which takes about 5 minutes. After your show is back on, see if you can recreate the issue. If you are still having the issue, the next thing to try is a check switch test. To do a check switch test, you press menu on your DISH remote, then press the numbers 6-1-1, (system setup-installation-point dish) you should be on the point dish screen. Go up and select "check switch" on the right-hand side, on the installation summary, select "test" at the bottom. The receiver will do some tests, make sure if you get a warning at the end, to select "cancel" on the warning. Once again you will let your receiver reacquire the signal, and see if the problem persists. If problems do continue, a technician will be needed at the home to correct the problem. If you are still having this issue, please email me at [email protected] and I will make sure you are taken care of.
Dec 12, 2010 | DISH Network DVR-625 DTV Receiver /...
My 622 DVR dual (DISH ) receiver has lost 3 local channels in a row ( SAT 61.5) . Connecticut 7385,7386,7387 - (ch 20,24,26.) Other tv's/ HD box and old 310 box converters work fine. I have unplugged,...
Hello, my name is Daniel Busa with Dish Network customer service. Whats probably causing the issue would be that either you're not getting high enough signal strength on the 61.5 satellite. Otherwise there could be an issue with the box if you swap it with another reciever in the home, and the issue follws it you'll need a new box.
Oct 19, 2010 | DISH Network ViP622 DVR DTV Receiver /...
Light in the set box is not changing red light is flickering. Green light is not coming inspite of changing the batteries in the remote control. I am having Dish TV in my house.
Hi, this is Mary with Dish Network Customer Service. It sounds like you are experiencing a power issue with your Dish network VIP622 DVR. You can try resetting the Receiver box by unplugging it for 10 seconds (if it is plugged into a surge protector, for the purpose of troubleshooting, plug directly into a wall outlet). Wait for receiver to reacquire satellite signal. If you are still having an issue, you will need to contact Dish Network because the receiver box will probably need to be replaced. I hope this information helps you.
Sep 03, 2010 | DISH Network ViP622 DVR DTV Receiver /...
Dish DVR 625. Turned on this morning and it had corrupted hard drive. The unit formatted and reset itself. Now I have no access to the DVR feature. When I press record I get an Error 024 - "Unable to...
Hey there! Becki Barned with Dish Network customer service here!! I am sorry for your DVR issue! To get that resolved, if it has not been already, try to unplug the receiver from the power source for 10 seconds. If thsi does not work, a new receiver may be needed. Blog back if any other questions!!!!!
Aug 24, 2010 | DISH Network ViP622 DVR DTV Receiver /...
0521 code on dvr
Hello! Daniel Busa with Dish Network I saw your post and would like to apologize for the inconvenience. If you've gotten that error message it may be a sign your hard drive is down. If you reset the reciever by unplugging it and it keeps happening you will need a replacement.
Jul 21, 2010 | DISH Network ViP722 DTV Receiver /...
My dish DVR HD control doesn't work
lumaes200,
You have indicated that you have a 622 DVR receiver, since this is where your posting was found. When you trying any of the DVR functions on the remote, do you get an error message (024 or 311) indicating that the function is not available at this time? If not, try unplugging the receiver for 10 seconds from the electrical outlet. This will reboot the receiver and re-acquire the satellite signal. Once the picture returns, try the DVR function. If the problem continues, please call 1-800-333-3474; we may need to replace the receiver. I hope this helps.
Ray Calo
DISH Network
Apr 02, 2010 | DISH Network ViP622 DVR DTV Receiver /...
How do I correct error code 04 when trying to playback DVR event?
Follow this article to fix the issue.100% Guaranteed
http://social.technet.microsoft.com/forums/en-US/itprovistahardware/thread/bd9763de-6141-45ea-990b-70c207fe3fb6
Feb 26, 2009 | DISH Network DVR-625 DTV Receiver /...
Error code 05
delete all recordings from hard drive unplug the receiver from the wall for 5 minutes and plug it back in, if 311 error message appears call dish network
Jul 27, 2008 | DISH Network DVR-625 DTV Receiver /...
DISH Network 625 Duo DVR Receiver (Remanufactured) Logo
5,040 people viewed this question
Top DISH Network Home Security Experts
Marvin
Marvin
Tom Chichester
Are you a DISH Network Home Security Expert? Answer questions, earn points and help others
