I have a brand new refrigerator (about a week and a half). I have noticed a chemical smell in the freezer and the refrigerator (more so in the freezer). I have tried baking soda and vinegar. The smell, however, doesn't seem to come from the visible plastic interior, but from the AIR when the fan blows. It smells like some kind of chemical from within. It is a little less than it was initially, but it is still there. I am not sure what is causing it or if it will go away. For the moment, I am not putting food in the refrigerator or freezer because I am concerned that it might be unhealthy. The compressor is also quite noisy. Your input is very much appreciated!
We have had the same problem, first fridge they came and took away and gave us a new one, then within days the same smell started again on the second fridge. How does Blomberg not know WTF is going on?
A bad chemical smell In the fridge is a waste of time it'll never go away
Heck for protective packing for shipment. check user manual for any packing that may need removal
SOURCE: Refrigerator Smell
Is the problem more in the freezer than the fridge section. If it is it is possible that on a defrost cycle the heaters which warm the coil may have warped and ar heating something they shouldnt. Another possibility is if there is something in the condensate tray (where the water collects) or something touching the compressor which runs very hot, or even the compressor relay if it is a 'plastic' smell. Smells are notoriously bad things to trace as engineers normally turn up when the smell is either gone or so faint as to not to detect. All I can suggest is trying to narrow the search area as much as you can and hopefully youll find it. Hope this is of some help.
SOURCE: chemical odor...
Is the unit working ok I think tech17 is trying to find out if you have a freon leak inside the unit??
try putting crumpled newspaper in it daily to get rid of the smell, the coolant if leaking should not cause any horrible smell, Freon they use today has very little smell to it. Frost free units have
heaters and fans in them to keep them frost free. It could be that a
fan quit and the heater overheated something around it."
Let me know if this helps, good luck
SOURCE: odor in fridge
Probably getting a new Fridge-mother doesn't want to continue to deal with repairs. Thanks anyway.
SOURCE: Chemical smell in refrigerator
hi,there,
well you gonna do is pull out all stuff inside freezer check any stuff that are with chemical substances, can good are open and expire if none., fine if you will not use it until you confirm the chemical substance that might contaminate your food.,have defrost and clean freezer mostly,then switch on again observed .,if necessary wipe it by w/ foam soap bubble inside feerezer if the is a bubbling and hizzing sound that the sign of leak on evaporator fin,you can notice if ther is a low cooling effect unyil cooling is gone,call service center have it replace your evaporator and check on the other compartment,if there an hizzing sound,if nothign just clean and have put a new staff better not to use the old one for saty precaution,have a nice day.
Your compressor just went bad...
Many times a freezer and/or refrigerator do not work right because of
a dirty condenser coil...there are also many other things that can go
wrong.
If
you are hearing a clicking or buzzing then check out the last two
tips.
If your refrigerator is running but warm, then...
Check
out these tips that I wrote about that... it is a great place to
start trouble shooting your unit...and something that you can do
rather then calling a repair person to do a simple thing for
you...
Refrigerator Condenser
Coil Cleaning
Refrigerator Repair
Refrigerator
Troubleshooting
Refrigerator Compressor
Refrigerator
Compressor
Start Capacitor and Start Relay
Refrigerator
or Freezer not Cooling or Getting Cold
heatman101
