Question about Alpine PDX-1.1000 1000W x 1 Car Amplifier Car Audio Amplifier
SOURCE: alpine pdx 1.1000 amp
These subs are dual voice coil I'm sure...make sure they are putting a 2 ohm load on the amp total, and also set your gain and frequency setting right. Set the frequency around 85 or 90, make sure the lo pass filter is on. Turn the gain ALL the way down and turn your stereo to the point right before your speakers distort....then slowly increase the gain until the subs are playing at full volume. This should not even be close to all the way up, and the subs should sound accurate and bold. Turning them past this point will cause distortion, in which case you should back off the gain a bit. Distortion causes power to cycle through the amp very rapidly and can cause blown subs and blown fuses. If you do not know how to wire both subs for a combined load of 2 ohms, please let me know what type of subs you have.
Posted on Aug 06, 2007
SOURCE: Blown fuses
This is a sign the you have poor voltage regulation. Which may mean that you are taxing the electrical system of your vehicle. I would suggest you adding a secondary electrical supply for you audio system. This can be done by adding an extra alternator and voltage regulator and battery supply. This will allow you to drive your audio system without having it (power supply) split between the vehicle and the audio system. The fact is your system is drawing to much current for the unit and your vehicle. You are blowing the 20-amp fuses which means the the amp is creating a currnet draw which is past the rated value of the fuses, which if done too many times could damage the power amp components in the unit. I would also check the ohmage reating on the speakers connect to the unit since you may have the wrong impedance which may also cause excessive current draw and actuate some sort of overcurrent protection.
Posted on Sep 03, 2007
SOURCE: Alpine PDX-1.1000 to a 10 "Alpine SWX-1043D
straight up. Since it has the power saving technology where it gives out the same power at 2 ohm and 4 ohm loads then u dont have to bridge it and since its a single speaker you dont have to bridge it and since it is a mono block oyu dont have to bridge it. just wire + to + and - to -.
Posted on Jun 02, 2009
SOURCE: Alpine PDX 1.1000 low power output - sub not loud
system not configurate properly go to a pro and let them do for you you have good equipment just need to put together rite.for wht you have you can get better sound than that,,good luck
Posted on Jun 26, 2009
SOURCE: how do you bridge an Alpine PDX amp
you have 2 + and 2- right? twine both speaker wires together. like + to + and - to - and then pick only 1+ and 1- to hook up and then you should double the power to the speakers only
Posted on Mar 25, 2010
Aug 15, 2011 | Alpine PDX-4.100 Car Audio Amplifier
Jul 11, 2011 | Alpine PDX-1.1000 1000W x 1 Car Amplifier...
May 19, 2010 | Alpine PDX-1.1000 1000W x 1 Car Amplifier...
Apr 22, 2010 | Alpine PDX-1.1000 1000W x 1 Car Amplifier...
Mar 20, 2010 | Alpine PDX-4.100 Car Audio Amplifier
Sep 21, 2009 | Alpine PDX-1.1000 1000W x 1 Car Amplifier...
May 14, 2009 | Alpine PDX-1.600 Car Audio Amplifier
Mar 30, 2009 | Alpine PDX-1.1000 1000W x 1 Car Amplifier...
Mar 17, 2008 | Alpine PDX-1.1000 1000W x 1 Car Amplifier...
Aug 31, 2007 | Alpine PDX-1.1000 1000W x 1 Car Amplifier...
Apr 14, 2017 | Alpine PDX-1.1000 1000W x 1 Car Amplifier...
Dec 25, 2017 | Alpine PDX-1.1000 1000W x 1 Car Amplifier...
Jul 18, 2011 | Alpine PDX-1.1000 1000W x 1 Car Amplifier...
70 people viewed this question
