Question about SanDisk Sansa m250 MP3 Player
How to delete songs from my Sansa m250?
Tried to delete songs from my mp3 player using Windows media but came up with error message that it was not possible. Help?
Posted by Marsha Le Mere on
Chris Hingee
  • SanDisk Master
  • 32,281 Answers
When you connect the MP3 player to yourcomputer with the supplied USB cable then computer detects the player as anexternal storage device or a Removable disk, you can then view the folder onyour MP3 player. Open the music folder and create a new folder on the playerexactly the same way you create a folder on your computer's hard drive. Toorganise your music, make a folder name with the name of the music album andplace the album's MP3 files in this folder, then copy the mp3 files from thecomputer into this folder.
You will then be able to select the music you want to play by the music albumfolder.To delete a filefrom your MP3 player, connect the supplied USB cable to your player and thenplug it into the USB port of your computer.
The computer will detect your player then click on this device to view thefiles, you can then click on the music file to highlight the file and thenpress the Del key to delete the file off your MP3 player.
Posted on Mar 26, 2012
  • Chris Hingee
    Chris Hingee Mar 26, 2012
5 Related Answers
Anonymous
SOURCE: deleting music from sandisk sansa E260 4FB mp3 player
you can change the usb mode in the sansa player settings to MCS then connect it to the computer, in windos xp the device will be recognized automacally. go to the explorer or to my pc and you should see it there.. go to the folder music and delete what you want,, you can copy music as well.
then desconect it safely and restart the device,, It will refresh the database and that's it.
you can change the USB mode bac to MTP if you wish.
Posted on Feb 08, 2008
Anonymous
  • 5 Answers
SOURCE: delete
The MUSIC folder is a "hidden" folder when in MSC mode.
To view it (assuming you're using Windows XP) go to:
My Computer>Tools>Folder Options>View Tab.
Scroll down till you see Hidden Files and Folders
and click on Show Hidden Files and Folders, and then OK.
You should then be able to see all the folders on your Sansa. The "hidden" folders will appear slghtly lighter in color. This is where you can delete click on folder then go toleft of screen to "delete this folder" (or open folder and click individual song" then go to left of screen
Posted on May 26, 2008
Anonymous
SOURCE: Sansa m250 playlists
First you need to set your Sansa m250 mp3 player to MTP mode:
) Tap your menu button and select "Settings" > "USB".
2) On this screen, make sure that there is a check next to "Auto Detect" and NOT "MSC".
Note: Music that was transferred to the player in "MSC" (Mass Storage Class) mode will not be accessible once the player is put into MTP mode.
However, the music can still be accessed by switching the player back to MSC mode.
To transfer a playlist using Windows Media Player version 10:
- Make sure device is showing as an "audio device" and in MTP mode
- Create a playlist by right clicking a song in the library, add to>additional playlists>new or by saving a now playing list
- Select the Sync tab and click "Sync settings"
- Check "Synchronize device automatically"
- Set "View" to "All Playlists"
- Place a check next to the playlists they want to transfer to device
- Media Player should then sync those lists once you hit OK.
Once you Sync for the first time a new folder "Playlists" will appear in your m250 using Windows Explorer. Once that folder is created you can even use Windows Explorer alone to create playlists, all you have to do is right click on a song and choose create a playlist. Double click on playlist > Reference Tab, on the window you simply drag and drop your songs.
Hope this helps
Posted on Oct 22, 2008
Anonymous
  • 82 Answers
SOURCE: how do you delete songs off of a sandisk sansa m240 music player
In My computer right click on the mp3 player and select format..then it will delete all songs..
Posted on Feb 28, 2009
Files not deleted from m250
Try this solution:
Hook up your mp3 player to your computer
Go to your desktop and double left click on "My Computer"
When it opens you will see listing that says "Devices with Removal Storage" your mp3 player should be listed there.
Right click on your mp3 player, and a window will open, right click on "Open" and now your files/songs should be visible.
Hold the left click down and drag it across all the files/songs that you do not want this will highlight the files/songs you do not want, release, right click and then click on "Delete"
Now you mp3 player should be clear of the files/songs you do not want.
Good Luck,
I hope this helps
Nov 14, 2009 | SanDisk Sansa m250 MP3 Player
Delete songs off my sansa m250 mp3 player
I just delete stuff from my WMP screen. View the list of songs you have on the device currently and then right click and 'delete from playlist'.
May 30, 2009 | SanDisk Sansa m250 MP3 Player
Hope this helps
Aug 28, 2008 | SanDisk Sansa m250 MP3 Player
Loading protected songs onto MP3 player
What I would recommend you to do is to delete the songs that are not playing for the device then transfer them back...Your SanDisk Sansa does not allow you to delete files from within the player.
Instead I recommend that you follow the steps below to delete the music
You have to make sure that the device is on MSC mode...then make sure your device is plug in to the computer..Then go to programs - accesories - windows explorer, find the SanDisk in my computer, go to media, music and delete them from there.
Either under sync panel in your windows media player it will show your music when it's connected. just click the plus signs for what song you need to get rid of, right click and click delete.
Hope this helps
P.S.Please rate accordingly...
Thank You
Computerrep
May 20, 2008 | SanDisk Sansa m250 MP3 Player
I cant delete files from my Sandisk M250 mp3 player
Just called Scan Disk if the device got a setting wrong:
Turn the Scan Disk on:
Go to Setting;
Select USB
Change the selection to Autodetect
Go back to Windows Media player the songs should show up..Worked for me.
May 18, 2008 | SanDisk Sansa m250 MP3 Player
Not enough space to listen
If it''s any consolation, the same thing happened to me after I loaded about 1.6 GB (~250 MB left) of music on my Sansa m250. I tried to delete the required 8MB, but the directory structure got destroyed to the point where my computer wouldn''t recognize the device. I called their technical support and they''re having me send it back to them for a replacement! It''s not you, but the player! I don''t know if there''s anything that can be done from a consumer standpoint.
Jul 09, 2007 | SanDisk Sansa m250 MP3 Player
My directory where MP3 are stored in sansa m250 cannot be seen on the desktop
Gagan, Please see my answer here http://www.fixya.com/support/t149468-san_disk Formatting your Sansa should do it. Let me know if it didn't and please rank my answer. Thanks, D.
Jun 16, 2007 | SanDisk Sansa m250 MP3 Player
SanDisk Sansa m250 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Jean Sintulaire
Daniel Dollive
Daniel Dollive
aliasger yq
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
