When I switch the laptop on nothing happens at all. This is despite the charger being connected to the mains. Prior to this, when the laptop was working, it kept coming up with the message 'battery low'. Now, even when the charger is plugged into the mains the charger does not get. Could anyone help me...I think it is the charger which is the problem but I'm not sure and don't want to waste money buying a charger when there isn't a problem with it. Many thanks, Hst
For a new battery, we advise that you update the BIOS of your laptop, and open the hardware automatic identification port of your laptop.
When you use it firstly, you need to discharge till 5%, then charge it about 11 hours. Usually, new battery need to fully discharge and charge for three or four times, which can achieve the best performance.
About the new battery, please set the power management of your laptop: Property -> Screen Saver -> power -> Power scheme -> Portable / Laptop -> please cancel about low battery alarm and serious shortage of battery alarm when use the battery.
For some laptops, you could try to close your power management tool to test your new battery.
You could try to take out the battery from your laptop, and put it back again, repeat several times. Make sure that it isn't a poor contact problem between the battery and your laptop.
If the battery works in higher temperature, the battery protection plate will work and the laptop restart program will make a termination order. You can take out the battery, put it back again, and avoid work in high temperature.
In order to avoid some damage to the battery, please note:
Please don't take out the battery when the laptop is in run status.
Please don't pull out the ac adapter frequently when the battery is charging.
Please use high quality and reliable laptop charger, not to use the universal laptop charger.
Are there something wrong with the new battery can not charging?
That's not usually the case. When equipment for the first time to recharge the battery, the instability of the voltage and current may cause the battery charge to 50% (sometimes more, sometimes less), and equipment stop charging the battery.
If this happens,don't worry. You just remove the battey from the equipment, recharge again. First charging a new battery may need several repeated process. Please be assured that this is normal.
Many people have reflected that Dell's notebook haven't recognised and charged the new battery problem. Usually, they solve this problem via BIOS refreshed.
Usually, please connect the battert with the power supply when you can refresh the BIOS. You can download the BIOS program from Dell support website http://search.dell.com/results.aspx?s=gen&c=us&l=en&cs=&k=dell+bios+inspiron+6400&cat=sup, automatically installed and automatically restart till to complete. Of course, you could check its use manual in advance.
Or you can visit http://www.batteriescenter.com.au/.
First of all remove the main battery and try again, the battery will often load down the power supply and in some cases kill the power, if no change! have your power supply checked out for the correct voltage, "TV repair shop on the spot"
SOURCE: dell studio 1737 mousepad not working
You can try the steps below and this definately should fix the issue.
Download and install the latest touchpad driver:
Uninstall the touchpad driver:
1. Click the Start button, point to Settings, and then click Control Panel.
2. When the Control Panel window appears, double-click the Add or Remove Programs icon.
3. Locate the software for your keyboard or mouse in the list below.
• Microsoft IntelliPoint software
• Logitech software
• DellTouch software
• Synaptics software
• Alps software
• Set Point software
4. Click to highlight the device name and then click the Remove button.
5. Follow the prompts to uninstall the input device driver/software.
Download and Install the Latest Touchpad Driver Available:
Please follow the link below to install the latest touchpad driver.
http://tinyurl.com/5k9tth
1. Locate “Input device drivers” and click on (+) sign next to it.
2. Select “Touchpad”, click Download Now. You may receive a warning and an option to run or save the file.
3. Click Save.
4. When the Save As window appears, designate a folder (desktop) to save the file that is being downloaded, and then click Save.
5. When the download is complete, go to desktop and locate the same file.
6. Right click on it and run as administrator.
7. Click on allow and follow the simple instructions to update the touchpad driver.
Please do not forget to rate the solution.
Regards,
Musheer.
SOURCE: Dell studio 1737 speakers crackle and pop.
My best guess is, if they crackle with the speakers but not the headfones, then replace the speakers. Must be a lose wire or something of that nature.
SOURCE: I have TWO dell studio 17 1737 laptops. One of
it could be the connection for the battery is damaged in some way, my advice would to take it to a repair shop, let the pro's have a look, power problems should always be dealt with by someone qualified, for you own protection. good luck with it.
SOURCE: My Dell Studio 1737 integrated webcam does not work
I recently purchased a new dell laptop and had similar issues out of the box. I ended up having to format the drive and re-installing the operating system from the disk provided because the original install was corrupt.
SOURCE: How do i fix Dell studio 1737 Battery EEPROM?
look for a new bios on dell website.. this should work.. if not.. it would be a mobo issue.. if your laptop just shutsdown then its a battery problem as long as you have warrenty you can get it replcaed.. all good.
