The camera experienced some physical force from the bottom and since then tape does not descend. When I close the tape slot, it closes but does not descend.
SOURCE: loading tapes
I have the same problem. If I remove the battery for a few seconds, then replace the battery and wait about 5 seconds, the tape compartment closes.
SOURCE: HDR-HC1 video camera won't close after you put the tape in. Hmm
MECHANIZAM fauly.repalace it by expert.
SOURCE: tape holder will not close
I am no longer a Sony product fan - this is the most unacceptable performance of any of their prodducts I have ever attempted to use. I have NEVER been able to record ANYTHING with this. The very first cassette - gave me the 'moisture' flashing symbol, and the cassette would not eject. Then after reading a recommendation on this board, I removed and reinstalled the battery a couple of times and the cassette finally popped out - now it won't accept the cassette and close - PLUS will not accept my normal NPfh30 battery and keeps telling me to reattach the power source. and after nummerous tires and camera resets, tried the NPFH100 battery and it tells me that I can not use this battery in the camera. I still get a C:32:11 code and so far this is a non-functional - malfunctioning POS
Sony HDR models that the carriage won't close is caused by the mode switch on the chassis. The mode switch controls the cameras function for loading and loading of the cassette. Basically tells the electronics what is happening. This becomes dirty and causes the chassis not to complete it's cycle on eject. Thus staying open. It has no idea where the mechanism is at this time. It can be cleaned and realigned but the chassis needs to be removed to get at it. Definitely a service depot repair. Sorry!
SOURCE: tape door won't close i
big problem with sony as you can see im a pro tech but had the same fault with mine. and it broke my heart 4 weeks old and sony dont give a dam ironicly a mate told me slam my fist under the bottom and it will close after hrs of trying to fix it i took his stupid advice and after many hits it closed and worked great for a few weeks
