Computers & Internet Logo
Question about LaCie Computers & Internet
I have a 1TB Lacie external drive that does not mount on my iMac. It did until today. The drive powers up but does not mount. I ran Disc Utility but this drive does not appear in the left hand column. I repaired permissions but still no Lacie drive. I also used different means of connection -- 400 firewire, 800 firewire and USB. It still would not mount. Could it be the power cable?? If the drive needs to be repaired how do I recover the data on it and get it repaired?? Thanks!
Posted by mjmillet on
Vladimir Frolov
  • LaCie Master
  • 2,075 Answers
I'd suggest to try the device on a different PC. If the issue persists the problem is obviously with the drive itself.
Posted on Jun 02, 2017
3 Related Answers
Anonymous
  • 326 Answers
SOURCE: No firewire 800 or 400 functions in Leopard for SIIG FireWire 800 + Hi-Speed USB Combo PCI Adapter
Unistall and reinstall through control panel. use the drivers it came with. Make sure the drivers are for ur OS. If not, check with manufacturer for proper drivers.
Posted on Mar 15, 2008
Anonymous
  • 505 Answers
SOURCE: I have a 1TB LaCie
First try in another Mac System if possible. If it works then its a problem its a problem with your FW800 port or the OS/drivers.
try uninstalling and reinstalling the drivers and also update the firmaware.
Link which will be of help ;
http://discussions.apple.com/thread.jspa?messageID=5780373
Thanks.
Posted on Oct 24, 2008
Anonymous
  • 507 Answers
1. Make sure to copy any files on your hard disk to another location because reformatting will erase them.
2. Click on your computer hard disk’s icon. Select Applications ? Utilities ? Disk Utility.
3. In the left hand column, click on the drive icon for the LaCie Disk (or the name of your external drive). Make sure you click on the first icon, not the second level volume icon.
4. Select the Partition tab.
5. Select the format type from the Format drop-down menu.
* Select Mac OS Extended (Journaled) (recommended) or Mac OS Extended.
6. Click on the Options button.
7. Select the type of partition you want to use:
* GUID Partition Table - for bootability on Intel-based Macs
* Apple Partition Map - for bootability on PowerPC-based Macs
8. Click OK.
9. Click the Partition button.
more using this
http://www.lacie.com/download/qig/bigdiskextremeplus_esata.pdf
1helpful
All my datas from my imac are now on my LaCie, how do I restore them back to my imac??
The data from LaCie hard drive can be easily restored back on iMac by making use of powerful iMac data recovery tool. Even I had encountered a similar problem and was wondering a way to restore the data on my iMac. Then I got know about this tool which helped me to recover all my data from iMac. Download the software available online and do reply me once you use it.
Best of luck J
Carter
On a lacie external usb2.0 firewire 400/800 1TB, I'm getting a blinking blue led whenever the drive gets connected via usb. I dont have a firewire cable to test, but the drive was working fine on same...
Plug in power first. Connect usb cable. Turn on drive. Under my computer/computer locate the partition called lacie. Open, run the exe utility.
My iMac does not recognize the Lacie 1tb big disk extreme external hard drive. No icon appears.
the first step will be to verify your power supply. When it is plugged to the wall power outlet, it should be silent (no hissing or high pitch noise) and the green light should be on on the power supply.. If it is not the case, replacing it might solve your problems.
Second step is to verify if it is an interface problem. Try using a different port on the drive.
If no success, start Disk Utility and look to the left if you have any mention of a drive of 1TB. If you do, the partition of your drive might be corrupted. You can try running First Aid from Disk utility if its available, else you will need to try a partition repair software or a Data recovery program.
There are a few available that you can get a free copy to see if the data is available before you buy.
Regards,
Imac is not detecting my LaCie External Hard Drive
Do you have a CD disc software installer of your external hard drive (F.A. Porshe 160GB).? If you got it, you must reinstall it, so that your Imac can detect it. Otherwise, find it at the internet and download it.
The power failure could have damage some stored data about your External Hard Drive in your Imac. That's why, you have to reinstall it. Send us your e-mail comments for us.
My external hard disc worked well until today. Now the external light continues to flicker quickly and the hard disc does not show up on my desk top. I have a mac running Mac OS X 10.5.7. The serial...
There is some thing wrong with file system on your hard disk drive.
Just unplugg it and wait for 1 min, Plugin again.
1) Go to Application -> Utility -> Disk Utility
2) You can see all the drives connected to the machine.
3) Select the drive from left side which acts as external and click on Repair disk button.
6helpful
5answers
Drive won't mount and makes slow clicking sound
A power supply failure can cause this; I've just been through it myself. If you have access to another LaCie drive, try its power supply on the "failed" one and see if it works.
Lacie 1TB external hd won't mount!
check wires connecting them together first, ok?
then, turn off the LaCie, connect to your MacPro, and then turn on the drive..
that should show as a mounted drive.
need printer drivers update?
Top LaCie Computers & Internet Experts
Marvin
Marvin
shadow
Mike
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
