Question about Dual Audio Players & Recorders
The arm swings out over the record, drops slightly and then returns to its resting position on its base
It seems that the special grease is old. There is a wheel moving the toneam. Remove any old grease from it and try again. If you need further instructions or a way to get new grease please refer to www. dual-board.de This is the worlds largest knowledge base for vintage Dual turntables. It is in german, but feel free to post in english, most people here in germany speak english, too.
Posted on Dec 03, 2015
SOURCE: Kenwood KD 3070 turntable
There should be a set screw that you can tighten in order to adjust the height return. If you do not have anything like this, perhaps your record is raised too much. How thick is your rubber mat? Do you have any other mats sitting on top of this?
- OPTiC
DJ Pro Audio
www.1200s.com
www.repairnyc.com
Posted on Sep 13, 2008
SOURCE: Tone arm keeps returning to rest on Crosley CR249
Hi, Try this. with it turned off. Lift tone arm across a record to the run out groove and set it down. Now power up and hopefully it will reset itself. In all honesty I would sell it and get a decent old school player. John. Styluscity.com
Posted on Nov 11, 2011
Nov 14, 2017 | Audio Players & Recorders
Mar 22, 2008 | Crosley 4-in-1 Entertainer CD Shelf System
Sep 20, 2016 | Audio Players & Recorders
Aug 18, 2014 | Audio Players & Recorders
Jun 14, 2014 | Crosley 0187SST Turntable
Jun 02, 2014 | Audio Players & Recorders
Nov 09, 2011 | Crosley 0187SST Turntable
Jul 11, 2011 | Audio Players & Recorders
Occasionally, customers have problems locking their Dyson vacuum in the upright position. This is a minor problem common with the Dyson DC07 and DC14 series and can easily be fixed by the customer. This page will show how to fix this problem. Although we show a Dyson DC14 Animal on this page, these instructions will work on any Dyson vacuum in the DC07 and DC14 series.
During shipping, moving parts on a Dyson vacuum can shift in position. One of these parts is a swinging arm in the base of the unit. This arm holds a removable elbow pipe in the vacuum's air passage. This arm can move out of the way so that you can clear out a blockage in the air passage. When this arm is out of position, the vacuum will not lock in the upright position. Fig. 1 Shows the base of a Dyson DC14 Animal locked upright. The red arrow points to the swinging arm. Fig. 2 shows the vacuum with the swing arm out of position. Since the swing arm is lower than it should be, it doesn't line up with the tab on the main body indicated by the red arrow.
Lean the handle of your Dyson all the way back and locate the black button on the right side of the vacuum indicated by the red arrow in Fig. 3.. Press the button down and hold it to unlock the swing arm.
While holding down the black button, pull the swinging arm (Shaded red in Fig. 4) all the way up. Fig. 5 shows the swinging arm in the correct position. Release the black button to lock the swing arm back in place.
The vacuum can now lock in the upright position as shown in Fig. 6. Note how the tab on the swinging arm overlaps the tab on the main body..
Dec 11, 2010 | Dyson DC25 All Floors Bagless Upright...
Aug 16, 2008 | Audio Players & Recorders
206 people viewed this question
