SOURCE: I can't read my screen because it it too llght
You should have a Fn button on your laptop, and pressing that, combined with the button that has a sun on it should raise your screen brightness, if your screen only has one brightness setting, and it got much darker all of a sudden, your LCD lamp probably went out, in which case it is probably better to buy a new laptop, because those are expensive to replace.
SOURCE: Cannot get Toshiba P@% S507 to see new hard drive.
you can't use a restore disk made for a specific hard drive with a much larger hard drive. This information is checked by the restore cd. You would need to contact toshiba and get a regular windows install cd.
SOURCE: When I power 0n it shuts down immediately
sometime some keys are pressed, check your keyboard
SOURCE: what is the largest hard drive supported by
The specs say that you have a 60Gb. hard drive. If the unit is less than 2 years old, you should be able to install a 200-300 GB. hard drive without any issues. The older laptops have a 137 GB. limit on hard drive partition space. You still can put a larger capacity drive, but you will have to partition the drive into c: 137GB, then the second partition can be any size. If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
SOURCE: How do I remove administrative password on p25
Try these folks.
http://www.lostwindowspassword.com/
Thanks, Joe
