Digital reset
There are two types of reset to TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
SOURCE: My Luxor LUX-19-822-COB Turns itself
Please see that the Auto Timer is corrected . Remove the power off the TV and keep aside so that it will reset. Now check for the timer set up. You can correct this settings by checking with the menu - timer settings.
SOURCE: i have bought a luxor
i brought a 19inch luxor telly and i only use it 4 karaoke NOT 2 have programs on ,and it kept comin up sayin shut down yes/no by remote i put no then its ok . but this kept happining so i took the telly back and got a 22inch same make a luxor first time set it up 4 karaoke and it happeded again. can any 1 help
SOURCE: i have reset my neibours luxor lux-16-822-tvb
I'm sorry for the difficulties you're experiencing in getting the channels. I suggest that you perform auto programming to resolve the issue.
Thanks for understanding. Please let me know the result after performing auto-program.
