Question about Ademco 1 Ademco 6150 6150pl3 6150pl2 Keypad Fixed English
How to get rid of FC on keypad - Ademco 1 Ademco 6150 6150pl3 6150pl2 Keypad Fixed English
Posted by Ann Parker on
Sean
  • 80 Answers
FC is for faliure to communicate. Need to check systems connection to monitoring station. Did anyone work on your phone line(s) or did you change your phone company or service? GL.
Posted on Apr 22, 2016
If keypad displays the FC code Can you still program a new master code?
I have never tried that because it has never been requested. "FC" is a higher priority. It means failure to communicate. So I would always correct that problem first and then change the master code. But I don't see why you would not be able to change the master code due to FC code. Gl.
Jan 31, 2015 | Honeywell Ademco Vista 20p And 6150 Keypad...
FC is flashing on my honeywell key pad, can I fix it
Yes you can i think this is for your keypad wiring have you checked your wiring for the keypad. check your data wires make sure they are identical on both ends.
Ed
Aug 13, 2014 | Honeywell (2) Honeywell Home Security...
Remove FC code Ademco Vista 15P alarm sysem
FC means failure to communicate, call your monitoring company to test your systems communication. If your system uses or used your phone line call on a cell phone so you don't get cut off when you system tries to call to monitoring company. gl
Jun 05, 2014 | Honeywell Ademco Vista 20p And 6150 Keypad...
Alarm will not set reads fc
that is a fail to communicate with monitering station
If you need further help, reach me via phone at https://www.6ya.com/expert/joshua_f823c77053c73844
Feb 22, 2013 | Honeywell Ademco Alarm 6150rf Keypad Lk
How to remove the FC phone system part from a honeywell vista20p
To properly solve the problem, the system must be reprogrammed using the installers code.
Nov 09, 2012 | Honeywell Ademco 6160 Alpha Keypad Vista...
How to get rid of FC on keyboard
FC is failure to communicate, to clear the keypad you need to get a signal to the central station where your being monitored, it will clear when the receiver acknowledges the signal
Mar 25, 2012 | Ademco 10) Ademco 6148 Keypad Fixed...
Honeywell vista 20p FC error code no monitor service beeping every 30 sec. need help how to stop beeping
If the keypad displays FC, that means that it is programmed to send alarms to a central station and a phone line isn't connected to the control panel. If you do not subscribe to monitoring services, it will have to be re-programmed. I can do that for you over the telephone if needed.
Thanx Mark Garrett
Aug 21, 2011 | Honeywell Ademco 6160 Alpha Keypad Vista...
There is a flashing error code on my keypad - FC. What does this mean? I had a service tech in to repair this problem and he said it was solved. No sooner did he leave and the "FC" began...
If you are not monitored, the FC will come up every time it tries to send a signal to a monitoring station. FC means 'Fail To Communicate" Contact me if you need further assitance
Jul 15, 2011 | Honeywell Ademco 6160 Alpha Keypad Vista...
Why FC show on ademco 6148 keypad,
Dec 07, 2010 | Ademco 10) Ademco 6148 Keypad Fixed...
Can only program one remote or keypad. which ever
You are going to have to do a process of elimination. I think you have either a bad remote or a bad keypad. Try programming a remote and then the keypad. If only one works then go with the other remote and the keypad. If only one works then program the two remotes. If the two remotes work then the keypad is bad or if you can program one remote and the keypad then the other remote is bad. Get rid of the bad one.
Oct 08, 2009 | Sears Craftsman LiftMaster Chamberlain...
Ademco 1 Ademco 6150 6150pl3 6150pl2 Keypad Fixed English Logo
130 people viewed this question
Top Ademco Home Security Experts
Marvin
Marvin
Tom Chichester
Are you an Ademco Home Security Expert? Answer questions, earn points and help others
