Question about JVC Televison & Video
JVC LT-W26X84 setup problem
Lost the remote and I need to run setup to allow channel 4 reception. I can get to the correct place in setup using the buttons on the side of the tv but I can find no way to make a selection.
Posted by TomB on
SD Tech
    Top Expert:
  • JVC Master
  • 14,553 Answers
You need the remote for this= an exact one!
GOOGLE THE MODEL NUMBER WITH "REMOTE" AND DO NOT BOTHER WITH A universal---waste of money as it will not have key functions you need.
Posted on Mar 25, 2012
5 Related Answers
Anonymous
SOURCE: Polaroid HD flat screen TV with DirecTV
Press input and then select dvd. After a few moments the dvd will start up if one is inserted.
Posted on Apr 18, 2008
Anonymous
SOURCE: PHILIPS 32PF7331/12 LCD TV
Press tv on sky remote then press help ,channel list appears . goto tv set use onset channel change button to scroll to hd channel .press volume up button onset to select.
Posted on Sep 29, 2008
inuyashian
SOURCE: Can't change channel using the remote or buttons on tv
Just run a channel scan, it should work after that.
Posted on Nov 11, 2008
Anonymous
SOURCE: JVC LCD TV LT-42X688-powers on, blank screen. no picture,no sound
Hi , I have the same problem with my LT-42X688,so i called the service of my extended warranty provider . the TV technician just left and told me the motherboard is the problem. he said its the third one this week he has seen with the same symptoms. he ordered the motherboard and i've got to wait 5 to 7 work days before the part will be in . I will keep you posted when the guy will return.
Posted on Jul 21, 2009
Anonymous
SOURCE: JVC LT-26DF7BK won't turn on
Just unplug unit from the mains and plug back in
Voila!!
Posted on Dec 21, 2009
XCAN'T FIND THE BUTTON TO RUN CHANNEL AUTO SCAN
First make sure that the Source is set to TV and a good antenna/coaxial cable is connected to the TV. Use the Input button on the TV (to the left of the power button) or the Input Select button on the remote. Use the up/down arrow keys to navigate through the source list and press Enter to select that choice. (On the TV, the Input button is the Enter button.) Next press the Setup/TV Menu on the remote (or Menu on the right arrow button or Enter. Then go down to Auto Ch Memory and press the right arrow or Enter. With the up/down arrows, navigate to Signal Type and set that to Air (for OTA channels) or Cable with the left/right arrows. Now navigate to Automatic Search and press the right arrow or Enter. Wait for the scan to be completed.
I hope this helps. The steps are shown in the manual for the LT-19D610 on page 18. The manual is available from JVC on the product page: http://support.jvc.com/consumer/product.jsp?modelId=MODL028825 . The direct link to the manual is http://resources.jvc.com/Resources/00/01/47/J55D0221B.pdf .
Dec 05, 2015 | JVC LT-19D610 19" 720p 1366 x 768 35000:1...
How do I run setup without remote
you need the remote---an original remote.
Mar 25, 2012 | JVC LT-26WX84 26 in. LCD HDTV
I have a JVC LT 26X575 that will not accept remote input for any function, but using the buttons on the TV allow the menu to be achieved and the sound to be raised or lowered. In TV mode it comes on on...
sounds like the remote batteries could be bad or the buttons on the remote need to be cleaned. some JVC TV remotes, I'm not familiar with this particular one though, can be cleaned using a clean pencil eraser. Be careful opening the remote because some parts can fall out or you can damage the connections to the LED emitter that sends the signal to the TV. Also the solder connections on that LED could be bad.
Jun 07, 2017 | JVC LT-32X575 32 in. HD-Ready LCD...
Lost manual remote control. The TV is JVC. Can ask for codes for the universal tv remote?
Hello
Four digit Universal remote codes for JVC TV are:- 0053 0060 0026 0197 0069 0247 0923 0012 0065 0067 0141
Three digit universal remote codes for JVC are:-
013/ 054/ 055/ 060/ 065/ 067/ 089
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand
Jul 10, 2011 | Televison & Video
Black and white tv
Hello
Your RCA, system setup has changed I thinks.To change this you have to go to the Menu option surf for system settings, and change the system reception to "AUTO".
Setup
The Setup menu allows you to access the GUIDE Plus+ system setup information. To access the
Setup option:
1. If the GUIDE Plus+ system isn't on your screen, press GUIDE on your remote control.
2. Press MENU to select the Menu Bar.
3. Use the right arrow to highlight the Setup menu selection.
4. Use the up and down arrows to select Change system settings, Review options, or
View demo.
Change system settings Confirms the settings you completed in the GUIDE Plus+
system setup are correct.
Review options Displays the GUIDE Plus+ system auto display options.
On Automatically displays the GUIDE Plus+ system when you press the ON•OFF
button on the remote control.
Off Disables the GUIDE Plus+ system from being displayed when you press the
ON•OFF button on the remote control.
View demo Runs the GUIDE Plus+ system demonstration
Note: If you have not completed your GUIDE Plus+ system setup, these options will not be available. A
screen will prompt you to complete your setup.
Getting In & Out of the GUIDE Plus+ System
To enter the GUIDE Plus+ system:
• Press GUIDE on the remote.
• Press and hold MENU for 2 seconds on the front panel.
To exit the GUIDE Plus+ system:
• Highlight a program and press OK to exit the GUIDE Plus+ system and tune
to the channel.
• Press GUIDE to exit the GUIDE Plus+ system and tune to the channel
displayed in the video window.
• Press CLEAR to exit the GUIDE Plus+ system and return to the original
channel
OK.
Dec 04, 2010 | RCA 32V420T 32" TV
Dish Satellite recently installed in my home supporting several tvs. MY JVC TV model LT32E478, designated as TV1, does not recognize any channels during program scanning. As a result, the timer on/off...
Hi mfaille
I`m going to help you with your setup but first;
Which connection are you using from the sat receiver to the tv?
Coax / standard rg6 cable?
Did you try to manually add(in the menu/tuner setup/find channel/add) the channel you need ?
May 17, 2010 | JVC LT-37E478 TV
Magnavox tv has cable channels 2-13 only. Lost original remote. Using a universal remote. Tried to auto program. It started scanning but when channel 14 came around, just fuzzy snowy picture all through...
The set needs to be switched from antenna to cable in the setup menu. It is capable of either antenna reception or cable reception. Ch 2-14 are the same frequency for antenna and cable but above 14 they are different. That is why the picture is stoping at 14. After you switch it to cable auto program again. Thanks for using fixya.
Nov 12, 2009 | Televison & Video
Black square on picture
it is in your remote. i solve this problem before. go to main menu and channels.
Jun 10, 2009 | JVC LT-40X667 40 in. LCD Television
RadioShack Universal Remote (Cat. 15-2147) - to use with JVC TV
programming a device: make sure batteries are installed correctly. Turn device on(for ex., your TV). Press TV button next to Power button on your 15-2147...Press and hold the little P button until the red LED lite blinks twice...enter the first four-digit code for your device(in your case,JVC TV...first set of #s is '0463' ) note: the LED will blink once as each number is entered. If the number is correct the LED will blink 2x. Note if the LED doesn't blink twice after entering the 4 digit code, begin again with the next set of numbers. For JVC the codes are 0463 and 0053. Once your remote blinks twice after entering in your TV code, press the power button. This should turn off your TV. Just use like any other remote. Hope this helps you.
Oct 11, 2008 | Radio Shack (15-2147) Remote Control
Televison & Video Logo
53 people viewed this question
Top JVC Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Todd Hill
Todd Hill
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
