My finger got in the way when sewing, I think I pushed the needle positoning mechanism to the right. The machine made a chattering noise and beeped. I turned the machine off, then back on a bit later. The needle does not go into the proper left/right position when the machine is turned on and does not reposition properly when changing stitches or stitch widths.
SOURCE: How do I change the stiches?
The brother website has a users manual for it that can be downloaded. Use this link to get it:
http://welcome.solutions.brother.com/bsc/public/us/us/en/doc/manual_index.html?reg=us&c=us&lang=en&prod=hf_ls2125eus&type2=5&flang=English&dlid=
SOURCE: Machine makes a loud noise and will not make stitches.
sounds like something is broken. best to get it checked out. take to the sewing machine doctor.
SOURCE: I was wondering if you could help me concerning my
i was able to find manual at www.ifixmachines.com
SOURCE: Brother M948 sewing machine - Bottom stitch
Go to brother.com and download a manual for free. Also, try a metal #15 bobbin.
SOURCE: This machine will sew properly & then start
you might check your bobbin case tension---turn the screw to the left to tighten----to the right to loosen
also after every project check the needle to make sure it's in good condition
I solved the problem after seeing this solution elsewhere: I simply brought the needle to its highest position using the handwheel and everything re-aligned.
