Question about Lexmark X4270 All-In-One InkJet Printer
Lexmark X4270 won't send out a fax
I am trying to send out a fax with my lexmark x4270 and i enter the number,scan the documents,and hit start,and it dials the number trys to connect but fails to send the fax,i have sent out many faxes before,so i am wondering why its not working now,could it be because i switched phone companies? i had comcast and it worked fine,now with ATT it does not seem to want to work
Posted by tifini pederson on
  • tifini pederson Mar 24, 2012
    i have tried putting the line directly into the normal phone line,the non filtered line not the dsl line,these are pretty important documents i'm trying to send out and with comcast it worked fine,i am really flustered any help is appreciated
JDTec
  • Lexmark Master
  • 4,338 Answers
If you have DSL. you need a filter on the line you are trying to fax through.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Posted on Mar 24, 2012
5 Related Answers
Geraldine Watts
  • 390 Answers
SOURCE: Lexmark X4270
Have you told your pc the fax equipment you want to use, and does it appear in the device managers list?
Posted on Feb 12, 2008
IQUIT
  • 3940 Answers
SOURCE: lexmark x4270 copy and fax
The definition corresponding to this error message is this: "The print carrier stopped before all of the data was used." To resolve this issue, please do the following:
  1. Power the printer off.
  2. Remove all cables from the back of the printer.
  3. Reinsert the power cord.
  4. Switch the printer back on.
  5. Check the operator panel to see if the 1201 error message is displayed.
  6. If the error message returns, the printer could be defective. Contact Lexmark Customer Support for further troubleshooting and warranty options.
reference: http://support.lexmark.com/cgi-perl/knowledgebase.cgi?ccs=229:1:0:439:0:0&framed=&docid=ENUS22014&relevance=1
Please rate this solution. =)
Posted on Jul 14, 2008
rjwharris
Harris
  • 102 Answers
SOURCE: Lexmark x2470. Fax solutions not working after going high speed
Please check that the Phone line for faxing is connected to a seperate NON FILTERED phone line. Not to the dsl line. You can use a line splitter for this. Also the dial up modem may need to remain in your computer for the fax software to dial out. Hope this helps.
Posted on Dec 09, 2008
nathan
  • 634 Answers
SOURCE: Can the Lexmark x4270 send a fax to an email address?
no you have to scan and create file and attach to email
Posted on Jul 07, 2009
spiceprince
Faizal Babu
  • 31 Answers
SOURCE: LEXMARK PRINTER
change the dialing mode from tone to pulse
Posted on Jul 24, 2009
My Lexmark x4270 will not auto accept faxes. How do I program that? If I am not right there to hit the start button, I won't get my fax. This is a HUGE problem for me. Thank you! Jennifer
Open your Lexmark 4200series All-in-one center page
Then above preview now, click on fax set-up utility
then once the set up page is open go to connection/dialing page and select what choice you want Manual/If a fax tone are detected/ always after so many rings then save setting.
thats it
How can I send and receive a fax from Lexmark x4270.?
You can send faxes via the operator panel, the All-In-One Center, or the fax driver.
Using the Operator Panel:
  1. Make sure your All-In-One is switched on.
  2. Load up to 30 sheets of your original document face down in the ADF (Automatic Document Feeder). Note: When you load small paper sizes, place your document in the center of the tray and adjust the paper guides to the edges of the paper.
  3. On the operator panel, press Fax.
Using the keypad you can:
  • Enter the fax number, and then press Black or Color.
  • Press Speed Dial, and then:
- Use the arrow keys to scroll through the list to find the number you want, and then press Black or Color. - Use the keypad to enter a two-digit number (viewable in the upper left of the display), and then press Black or Color.
The All-In-One scans your document and sends your fax to the number you entered.
Using the All-In-One Center:
  1. Make sure your All-In-One is attached to a computer.
  3. From your desktop, double-click the Lexmark 4200 Series All-In-One Center icon. The All-In-One Main Page appears.
  4. Under Productivity Tools, click Fax an image or document.
  5. Follow the instructions on your screen to complete the task.
For a more comprehensive guide on how to send and receive faxes using your Lexmark X4270 printer, please refer to the Lexmark X4270 User's Guide.
Trying to print and my computer isn't picking up on my printer just the fax and my lexmark x4270 is saying load document eachtime PLEASE HELP NEED RESUME TODAY!!!!????
Try to update your printer driver. Please visit the Lexmark website at http://bit.ly/gKXn7F to download and install the printer driver for your Lexmark X4270. Select your operating system, download and execute the file.
1helpful
I haVE ONE NEVER MADE A FAX CAN YOU GIVE ME THE STEPS ON HOW TO MAKE ONE QUICK MY DAD JUST PAST AND I NEED TO SEND FAX AND I DONT NO HOW MY DAD DID IT ALL THE TIME PLEASE HELP
How to fax: 1. Load your original document face down in the ADF. Adjust the paper guides to the edges of the paper. printtech_49.jpg
2. On the control panel, press Fax. 3. Use the keypad. Enter the fax number and then press Black or Color. The All-In-One scans your document and sends your fax to the number you entered.
For more information, you can also refer the the Lexmark X4200 Series User's Guide. I hope this information has been helpful. Thanks.
How do i fax several docs. to same number/?
Actually, it's just like sending a single-page document to a particular number but you just have to insert the multipage document in the feeder. Here's the Lexmark X4270 User's Guide for your reference: http://www.lexmark.com/publications/pdfs/2007/4200/ug/en/frameset.html. Go to Sending a Fax in Faxing for instructions on faxing multipage document. However, if you're gonna be having a mechanical problem on the printer, I suggest you contact Lexmark Technical Support to further investigate the problem. Thanks.
Fax
Hi. To send fax on your X4270 printer, place the document in the feeder facing down. For additional information on how to send a fax, here's a link to the Lexmark website where you can download the User's Guide. http://bit.ly/d3t61I . Click on Publications tab on the center of the page. Choose User's Guide (Lexmark X4250, X4270). It will give some instructions, as well, on how to do other functions/features of the printer. Hope this helps.
Lexmark x4270 will send fax but won't receive
Hello sir; The better solution is replace a phone cable.
Lexmark X4270: How to scan directly to PDF format
Does this model come with a "Lexmark All in One Center" software ?. If so, try this link and see if it helps:
http://support.lexmark.com:80/perl/support/support.cgi?relevance=0&ccs=229:1:0:439:0:0&mode=DOCS&doctype=KB&term=pdf&docid=ENUS20322
If the "File" option does not work above, you can select the option "Send Scanned Image to" - 'Acrobat Reader'.
Why can't i send a fax? Also why can't I get a english manual?
You can visit official site of lexmark.com and take full instructions, how to work with yours fax.
1) you must to connect yours fax prooperly to telefon line
2) insert document
3) enter number
4) press "Start" (or "OK")
Lexmark X4270 All-In-One InkJet Printer Logo
Top Lexmark Office Equipment & Supplies Experts
Ekse
Randy Prevost
Randy Prevost
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
