Question about RCA F27450 27" TV
Rca tv wont stay on turns on then blue light accross the screen then goes off in seconds
Notice dim standby light is on
Posted by terbnax5 on
SD Tech
    Top Expert:
  • RCA Master
  • 14,553 Answers
It is listed here as a 27 inch set--can you confirm the brand and model number for me ???
Posted on Mar 25, 2012
5 Related Answers
Anonymous
  • 72 Answers
SOURCE: Tv won't stay on
it is a brandnew tv, so expected that it is under warranty,, it best for you to return where you bought so the warraty will not void. Big possible of factory deffect.
Posted on Dec 26, 2007
zimcloud
  • 135 Answers
SOURCE: 36 inch RCA 36v430t
Mike-It looks like the power supply is going on your tv-it can be replaced. This happens, usually, when little kids are playing wth the remote or power button on the tv. Turn it off and on a whole bunch of times in a row, kids love to do that, and it burns out the power supply part- to make a CRT tv like your RCA36 incher- which is a beautiful machine- I have the RCA/PROSCAN 36 incher-LAST longer...You should always wait 5 min between turning it off and on. Don't ever sell it. This one is worth fixing. It has better color and sound Than the new plasmas and lcds-The Pros know this. Be carefull, they might try and talk you out of it-so they can fix it and have it for themselves. So what if it's not High Deff. It's a great set.
Posted on Jul 02, 2008
Anonymous
SOURCE: Standby light
I have same problem. Can anyone help?
Posted on Nov 13, 2008
Chi Chu
  • 8457 Answers
SOURCE: rca truflat 13
Ur video board that connected to the CRT(tv tube)long neck.It needed resolders the board it have cold solders.U know how to solders, resolders the ssockets pins that the CRT video board connected to.
Posted on Nov 10, 2009
Anonymous
SOURCE: my rca console tv has white horizontal lines
Cold solder joints on the flyback transformer circuit board - probably because RCA used feed-thru steel rivets on their boards. Re-solder the connections using a good solder flux for clean solder joints and this will fix prob. The joints with the dull, pitted finish are the problem joints.
S. Hampton
Posted on May 16, 2010
RCA LED50B45RQ TV, white line flashes accross screen, then goes black and wont turn back on. Red light on bottom goes off and wont come back on either.
Sounds like T'Con board fault. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Search the site by type in the "brand name" of your device, in the "Search box at the top right of the Homepage" to get gathered related posts.
Dec 03, 2016 | RCA Televison & Video
Blue power light is on the tv cant turn it off
Unplug the TV wait 10 Seconds and Plug it back in. Should work fine
Sep 26, 2009 | RCA L42FHD37 42 in. LCD HDTV
Tv keeps cutting off
If its a vertical line I would check your vertical output. What model set do you have. You may have a self diagnosis feature if your standby power is operational. Hard to say without knowing the model youre talking about.
Jan 02, 2008 | Televison & Video
52 RCA DLP 1080P Television with NO picture and buttons flash
IF you would like help diagnosing your set. Go to the enclosed link. They have the service manual for your set and offer unlimited chat support for only 29.99. Just click on your sets manufacturer and you will see your model. Then click on the contact us link and provide your email address and they will email your manual and instructions on how to obtain your support. I am one of their techs. This manual contains step by step procedure for troubleshooting Your RCA DLP Light Engine
http://servicemanuals.vstore.ca/
Dec 30, 2007 | RCA HD61LPW175 61" Rear Projection HDTV
RCA F27450 27" TV Logo
216 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
