I am running Vista and when I connect the hub I get the message - "cannot install - drivers not found."
SOURCE: Belkin F4U017 7 port USB
I just had the same problem and was able to figure our a permanent fix.Judging by the date of you post, I'm guessing you've already remedied this problem one way or another. But just in case you haven't or someone else is having the same problem, I'll go ahead and post what to do. First, make sure you leave the USB hub plugged in right now so that Device Manager lists what it thinks is the Bluetooth device. Go into Control Manager > Hardware & Sound > Device Manager. Right click on Bluetooth device that is showing up in error. From the dropdown box, select Properties. Click the Driver Tab. Click Uninstall. Check "Delete the driver software for this device." Click OK. Unplug your USB hub for a few seconds, then plug it back in. Windows should now recognize it as a "Generic USB hub." You should be good to go. Just remember not to install that update again or try to update the driver for the Generic USB hub. If you do, you'll end up with the same problem. I hope this helps someone out there.
