Even if theres full battery i have to charge it then it works.. aslong as my fones on charge it wont turn white but if i take it off charge after between 5 mins and 1 hour it will go back white again.. what should i do??? helllp...
SOURCE: blackberry curve 8320 wont charge? Keep sayin
Have you tried different chargers?
It's either the voltage regulator in your curve or a very weak almost dead battery.
You can test the batt if you have a friend with a curve, swap batteries in your phones and if yours works again and his does what yours did, get a new battery and all is well. If yours keeps acting up with the swapped battery, it may be time to get a new phone.
SOURCE: blackberry curve won't turn on...
Wipe it to start over. Sometimes when you change or add something like a THEME or a download it HOSES the BB completely. So delete what was on there and don't download a theme or any other wacky add-on.
To Sanitize or Clear out all the information in a Blackberry Device
Scroll to select the OPTIONS icon and press [Trackwheel] to select.
Scroll to select SECURITY and press [Trackwheel] to select.
On some units you may have to select GENERAL SETTINGS before getting the next menu.
Press [Trackwheel] again to access the Menu screen for the security.
Scroll to select the WIPE HANDHELD and press [Trackwheel] to select.
Scroll UP to select CONTINUE and press [Trackwheel] to select.
Type blackberry on keyboard to confirm the action press <-| key.
System responds with ERASING INFORMATION.
SOURCE: Hello, my blackberry curve 8520 has a horizontal
I have the same problem, but it's a vertical white line. I have a BB Curve 8310. From what I've researched on the web, it seems the LCD screen wud have to be replaced.
SOURCE: blank white screen on my blackberry 8520 curve from switch on
Sounds like your screen is physically broken. If your Somebody needs to open your Blackberry and replace it. If you want somebody else to do it for you go to Blackberry Repair. If you want to do it yourself, here is an Blackberry 8520 Repair Guide that shows how to repair a Blackberry.
SOURCE: Phone won't turn back on
No. There are some sellers on ebay which sell you a kit to clean up water damage on your cell or BB, but it's super hard to do without breaking the device. Even with instructions, it requires you take everything apart etc.. And its like $40-50 for the kit.
Sometimes you get lucky and up to 3 weeks later the device will dry out and work, and I've had some work the next day.. but only about 33% of the time do they come back at all...
