I just got this stove a few weeks ago and was not aware that the screws that hold the bake element in place had been removed. then somehow the element got pulled out of place. So when i open the oven door it caused the element to arch off the metal frame and burned one the connector ends off. So I need to know howto re-connect the tip to the element
If the bake element terminal was shorted and burnt off, you will need to replace the bake element with a new element. Supply a model number and brand of appliance and I will supply a part number for you. Soldering will not hold as the solder will melt and break away shorting again. Possible to spot weld it if enough terminal left.
the thing is that it's really old and i can't find a model number on it anywhere. i just know it's a sears kenmore self cleaning oven. white in color. i have searched online for hours and can't seem to find one that matches mine.
Take a digital picture of the element. I will see if I can identify it. We have over 500 different elements in stock. Eric
SOURCE: my ge spectra stove bake element is not heating
I have a GE Spectra stove. The top element over heated and broke in half.
SOURCE: I need to replace the element on the bottom oven.
Hi. Hold the fan with your hand, and unscrew center nut, N.B It is a left hand thread, so unscrew it clockwise as though you were tightening it the conventional way, and vice versa for tightening it up.
Please `rate my solution.
Thanks.
P.S. You can bend the fan blade if needed.
SOURCE: FRIGIDAIRE STOVE MODEL FEF316BSC I WAS BAKING
Don't worry! Your element probably blew out. It's no big deal. It happens. Call us for parts. 9728590929. It's really a simple repair, probably one of the easiest to do. Hope this helps!
SOURCE: No power to Magic Chef Electric oven
I'm not familiar with this oven, but it ought to have protection against this kind of exciting burn-out.
This could be a fuse: find it and replace it, or it could be a circuit breaker: look for a reset button.
As I said, I don't know this oven; this attempt to help is based on the general idea that it ought to have some built in protection.
SOURCE: I need to replace baking element on model
Hello there:
By the way that you have described it this is right things that i have learned is be careful taking out the screws i have seen them strip out or break and dont tighten them too much once it is snug turn it 1/4 turn more
also clean the area that it connects to really well so it does not short out the new element and Please do not forgett to unplug the oven ok
hope this is very helpful for you
Best regards michael
