The problem which happens with my camera(canon IXY 200F) shows the memory card locked,shows the photos but not takes new one (photos) thanks for help..
SOURCE: Memory card error
Either the camera or the card is faulty. There is not a setting which will cause this problem. Try a different memory card, if the problem persists you will need to get the camera repaired.
SOURCE: screen reading memory card not initialized
I bought a new memory card for my finepix A330 camera When I turned on the camera after putting in the new card, the screen read "card not initialized" and won't take photos.my son is going holidays 13/9/08 could you help me please Alex Richardson
SOURCE: card locked
Have you tried looking at the memory card? Sometimes there is a switch on the card itself that slides up and down to lock, or unlock the card for usage. Hope this helps! (It should be white, and a semi-translucent plastic.)
The trouble with trying to format large cards of 1Mb or 2 Mb is that in order to do so you need your original card or a card that currently WORKS. I have one of 16 Mb. Go to Fujis web help page and download the firmware fix "FinePixA340" to your PC. Run and extract the data file "FPUPDATE".Now you have to put this file onto the old card. I pasted it so it was "beside" the DCIM folder ( NOT the next one down 100_Fuji folder or it won't work). To copy and paste you may have to connect the camera to the PC or use a XD card reader/writer via a USB port. Having done that, put the card back into the camera if you used a XD writer and switch off the camera. For the next bit make sure your batteries are good or connect to a power supply. Hold down Disp/Back button and THEN turn on camera. It should have detected the new firmware data file. Follow the simple instructions-say yes and let the data file load--takes a few minutes. The camera should say the new version !.22. Now that the firmware has been updated , you can now format your NEW LARGER cards 1 or 2 MG. So take your old card out ,put the new card in and format. It worked sweet as a nut for both 1 and 2 MG. The trick is to use a card that already works,load firmware file onto this , update file onto camera, then format a larger card. Its what they don't say exactly that causes frustation. Happy formating campers
SOURCE: My camera shows CARD LOCKED
Try taking the card out of the camera and clicking the side of the card - there may be a little gap on one side of the card or a small button that you can slide up and down and then reinsert your card.
Thanks for your answer,not helpful,I am trying it,this card before this problem happens, was OK .
